About had it. Help me figure this out! (update)
Old Apr 10, 2008 | 12:11 PM
  #16
97BBlackZ's Avatar
Originally Posted by cvccbum
Sounds just like when a piece of my starter broke off and was hitting the flywheel.
Starter was fine. That was my like 10th thought after pulling the intake lol.
Old Apr 10, 2008 | 01:22 PM
  #17
Dave1980's Avatar
possible clutch fork? I know the retention bolt for the fork can get old and break. I had that happen to me, but it made my car stall. It had a similar sound.
You can check this by taking the slave cylinder off and peeking in to see your forks orientation.
Old Apr 10, 2008 | 01:35 PM
  #18
cvccbum's Avatar
Yeah, that definitely sounds flywheel related. I've never heard a rod knock that insane, lol.
Old Apr 10, 2008 | 01:37 PM
  #19
Originally Posted by 97BBlackZ
Well i youtubed Rod knock and found a WRX with the EXACT same noise. I'm about to go double check the filter and oil and look for shavings. I'll cross my fingers. And by RMS housing bolts what do you mean? The torx one that surround it? i'll post a link in a min
http://www.youtube.com/watch?v=x9LJP1mw0es
I have the valve covers off and everything looked fine.
...the bolts that hold the RMS housing on. They are not torx. The stud for the one nut has a torx head, though.
A rod knock on a WRX might not sound the same as yours. I would not try to compare the two. Still, you might actually have a rod knock.
Old Apr 10, 2008 | 01:38 PM
  #20
97BBlackZ's Avatar
K well i'll check everything else. The trans is out and i didn't see anything wrong with anything while i was taking it all apart. I drained the oil and cut the filter open and took it out. There are very few small specs of metalic stuff. Would that be enough to consider a problem?
Does anyone have a clip of a lt1 rod knock?
The tranny is out. clutch and PP off and i was just looking at the RMS a few days ago. All the bolts seemed to be right. (altho i didn't take a wrench to them). So i'm basically out of options and it would HAVE to be something internal right?
Old Apr 10, 2008 | 02:02 PM
  #21
Kaj's Avatar
Kaj
Is/was your exhaust hitting on your tunnel brace? I've never heard any noise like that, unless it was flywheel related.
Old Apr 10, 2008 | 02:11 PM
  #22
Here is a classic one courtesy of Dave88LX that used to post here.
Old Apr 10, 2008 | 02:32 PM
  #23
97BBlackZ's Avatar
It was after i had to replace my trans cross member. but theres a cm inbetween them and it only hits when i get on it sometimes.
Hm. your right that doesn't lound like my noise at all. Man i hate this car lol. The only problem is i can't think of anything around that area that would make that noise at that tempo. Is there a valve or anything in the back of the intake that would cause this?
When i got under the car when it was running to check, it sounded more like it was coming from the back of the motor on the passenger side. I did take a screw driver, placed one end to my ear and the other right to where the RMS housing way and didn't hear much. Same with the oil pan. It all sounded 'normal' to me and more like it was coming from somewhere around the top of the transmission. (although thats just what it SOUNDED like)
p.s. thanks for everyones help and suggestions so far!
Old Apr 10, 2008 | 06:02 PM
  #24
97BBlackZ's Avatar
Quick question. Should there be ANY metallic specs in the oil filter? There are very small shiny pieces. And i can't tell if some of them are connected to the magnet because of the oil or if they're metal lol.
I found no metal shavings in the oil tho
Old Apr 10, 2008 | 08:47 PM
  #25
klrz28's Avatar
How many miles on the motor?
Old Apr 10, 2008 | 11:10 PM
  #26
97BBlackZ's Avatar
What i was told was about 20k when i got it. So about 35-40k now.
Mods in sig.
Old Apr 13, 2008 | 11:02 PM
  #27
az0884's Avatar
Ive had an alternator that sounded like that when the bearings were bad.
You may be able to tell the noise is nowhere near the alternator but if not then maybe its worth looking at.
Magenta_Hearts
Mar 25, 2015 10:24 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
BPS
9
Mar 5, 2015 10:51 PM
smokin25th
Jan 1, 2015 09:06 AM
ANDYZ28
Dec 29, 2014 09:13 PM
