95 lt1 z28 wont start
Engine spins but it does nothing at all to try to start. Replaced the optispark also checked that the coil was working ( sending spark ), but nothing at all. Will the ignition module have anything to do with this. thanks
check the fuse for the icm its a 20a i think if its blown then your icm is mostlikley shot, please include a sig with what is done and miles on car. is the coil wire good? check for continuity. check for fuel pressure make sure fuel pump is priming when key is on, ses light on? if so check for codes
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
