95 lt1 z28 wont start
Old Mar 30, 2008 | 04:28 PM
agustaf4's Avatar
Engine spins but it does nothing at all to try to start. Replaced the optispark also checked that the coil was working ( sending spark ), but nothing at all. Will the ignition module have anything to do with this. thanks
Old Mar 30, 2008 | 04:32 PM
red 95 z28 lt1's Avatar
check the fuse for the icm its a 20a i think if its blown then your icm is mostlikley shot, please include a sig with what is done and miles on car. is the coil wire good? check for continuity. check for fuel pressure make sure fuel pump is priming when key is on, ses light on? if so check for codes
Old Mar 30, 2008 | 04:38 PM
brianswimmer23's Avatar
yea we need to know more about what has been done to your car! and what code's if code's your throwing!
Old Mar 31, 2008 | 11:45 PM
Compstall's Avatar
The ICM fuse is a 10A.
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
