94 lt1 swap in 97 car
Old Sep 10, 2010 | 09:48 PM
450hplt1's Avatar
I put a 94 motor and tranny in my 97 car with a 97 computer and wiring harness and everything seems to be working except I'm not getting any spark. Does the crank sensor have to be plugged in or should it still fire without it? If it should still fire, what wires to the coil should be hot? Thanks.
Old Sep 11, 2010 | 06:35 AM
What did you do about the Opti harness plug? The 94's unvented Opti uses a different length connector than the 97's vented Opti. You would need to change out the short Opti harness from the bracket on the side of the intake manifold to the Opti.
When you do get it running, the knock sensor will set a code, since the 94 uses the low impedance sensor and the 97 uses a high impedance sensor.
The crank position sensor is only used for misfire detection and should not stop the engine from starting.
Old Sep 11, 2010 | 10:27 AM
450hplt1's Avatar
I left the long optispark harness on the motor. Any more ideas?
cmdeshon
Dec 12, 2014 10:51 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
smokin5s
Jul 24, 2003 10:47 PM
