'93 LT1 F-Body owners ... inside, please help me!
Re: '93 LT1 F-Body owners ... inside, please help me!
2 things. the guys at Painless wiring told me the computer need to see something from the VSS or it wouldnt run right. it didnt need to be accurate, just something.
also, for a 93, is the vats just a fuel pump enable/disable signal? if i wire the fuel pump up on a relay/switch to the battery, it will still run, right? or does the vats also effect ignition?
Originally Posted by SnakeSkinner28
Im confused as to why you would need a VIN# in order to get a PCM. Just have someone write a program for you for the 96 and load it via computer. Its not that hard, and cheaper then buying a complete PCM. But either way something doesnt sound right as to why you need a VIN# just to get one, i wouldnt think that matters.
formula79
207
Aug 10, 2002 08:59 PM
formula79
51
Jun 30, 2002 07:08 PM
formula79
18
Jun 24, 2002 11:41 AM
formula79
40
Jun 21, 2002 03:44 PM
formula79
23
Jun 20, 2002 01:42 PM
