4 bolt splayed main caps for my le2/125hp n20 setup? ---
Old Oct 27, 2006 | 01:32 PM
AlwaysCode390's Avatar
Lightbulb 4 bolt splayed main caps for my le2/125hp n20 setup? ---
Would it be a good idea to fork over the extra $500+ for a 4 bolt main splayed cap setup on my le2/125hp n20 shot ( around 600hp crank )? Thanks ---
Old Oct 27, 2006 | 01:54 PM
526 SS 96's Avatar
4 bolt mains are always a good idea if you can afford them.
Old Oct 27, 2006 | 04:00 PM
Sounds good to me....get them done when the block is getting clearanced for the stroker crank/overbored right (machine shop does them)? ---
Old Oct 27, 2006 | 04:15 PM
526 SS 96's Avatar
Yes, the machine shop will do it when they are doing the rest of the engine. They will allign bore and hone it to make the new caps fit right.
Old Oct 27, 2006 | 05:02 PM
FastZinTennessee's Avatar
I vote go for it. I did, I'd rather overbuild than underbuild, it costs more money to do the latter!
Old Oct 27, 2006 | 05:42 PM
I totally agree, now....which brand has the best setup? Thanks ---
Old Oct 27, 2006 | 06:03 PM
NVetro's Avatar
Definitly splay those main caps. Even if I was rebuilding the stock motor I would splay it. Build that sucker once and be done with it, cus ya never know what the future mite hold. I went with a set of Program (sp?) main caps, i think they were $175 or something? I forget, yea give them to your machine shop and then can align and hone them. They can also clearence your dipstick as some people have issues with the dipstick tube and the splayed main cap. I mean you can go all out and get a 4 bolt rear cap also, and center cap too. But most just do the center 3, you will be fine with and standard 3 cap main splay.
Old Oct 27, 2006 | 06:05 PM
OOOH NVETRO that is some GOOD info. I heard a lil bit about the dipstick problem AND the 3 cap deal. I appreciate it ---
Old Oct 27, 2006 | 07:04 PM
oneslowz28's Avatar
got mine splayed for a little bit over 400
Old Nov 7, 2006 | 06:16 PM
Just got the eagle caps , 3 set, for $80 shipped .... couldnt find the center and rear cap....can someone link me to someplace to get them?! Thanks ---
Old Nov 7, 2006 | 06:59 PM
NVetro's Avatar
They are pretty pricey and you more than likley do not need them. Most people just do the center 3 like I said....but if you search aorund, I definitly saw that at "Programs" site, they are the ones that made my main caps.....correct my spelling guys as I cannot find it via google. But your not going to need them, splay the center 3 only, its what I did :-) I remeber my engine builder saying something about the oliver 4 bold splayed main caps are VERY strong, strong enough that they go through a few tips line honing the sucker. Just thought i'd put that in there for future search results.
EDIT:
Found the website: http://www.pro-gram.com/
Old Nov 7, 2006 | 08:46 PM
kline454's Avatar
Im building a 383 and going to put a 100-175 shot on it with, the 2 bolt main with arp bolts, theres many people putting 500+ to the wheels on the 2 bolt but its better to go with the splayed if you got the cash.
Old Nov 8, 2006 | 12:06 AM
SStrokerAce's Avatar
Ouch.... I'd replace the splayed bolts on those caps with some ARPs.
You don't need a center and rear cap in most instances and the rear is around $255 alone.
Bret
Old Nov 8, 2006 | 11:53 AM
Pro-Gram Engineering
http://www.pro-gram.com/index.jsp
Old Nov 10, 2006 | 08:52 AM
Thanks Bret for the tip, and the other guys for the links ---
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
