396 pistons for a 6' rod?
Old Feb 13, 2005 | 10:47 AM
my94blackz's Avatar
Who makes pistons for a 396 with 6'rods? Im after about 11.5 compression, and a good forged piston. I already have the rods so i really dont have a choice on rods. Plus who makes the lightest weight crank?
Old Feb 13, 2005 | 12:13 PM
OldSStroker's Avatar
Re: 396 pistons for a 6' rod?
No one...for 6' rods. Sorry, I just had to do that.
Wit a 9.00 deck you are going to need a compression height (CH) of about 1.06 to go with 6 inch rods. It can be done, but it may not be the best idea. Depending on the rest of the engine, it may need to be a custom piston.
So why do you want the lightest weight 3.875 stroke crank? Certainly not to save money. How high do yo plan to spin this 396? What kind of heads?
If you have to design around existing rods, you might consider a 383 with 1.125 CH pistons. You have a number of good choices in non-custom pistons, and you will spend considerably less money.
My $.02
Old Feb 13, 2005 | 07:01 PM
my94blackz's Avatar
Well i like lightweight stuff, and i was wanting all the cubes i could get. I got a 233/239 cam from combo, so 6500 is about the max. The heads will be 2.00 1.56 P&P and probably shaved depending on the piston. The block is 0 decked.
Old Feb 13, 2005 | 08:10 PM
rskrause's Avatar
Moderator
It doesn't really make sense to talk about "zero deck" unless you already have the rotating assy. It's only "zero" if the deck height = stroke/2 + rod length + CH. As Jon said, you will likely need a custom piston to run a 3.875" crank with a 6" rod. Typically, a custom CH will run ~$10 extra per piston and will be available from any of the high end piston manufacturers.
Rich
Old Feb 13, 2005 | 08:26 PM
my94blackz's Avatar
27 thousands off one side of the block and 29 off the other, if that helps any. how much would a set of custom pistons run?
Old Feb 13, 2005 | 09:21 PM
You are already below 9.000 deck. Has this block been rebuilt before? Maybe you don't want to use it. It might be tired, and may already be more than .030-.040 big on the bores.
Cost of pistons? What's you budget for this engine? The difference between shelf and custom pistons, maybe $80-$100 as Rich said, isn't significant in your total budget.
IMO, you might consider getting professional help on the engine design, or are we just talking 'fantasy motor'?
Old Feb 13, 2005 | 09:28 PM
my94blackz's Avatar
lol no i had the engine done last year, im sorry i should have stated the b4.
I had my engine done last spring, i had it punched 30 over and decked as previous stated, i bought forged weisco pistons, a lw crank 3.48, and lw 6' rods. I shoulda stroked it then but i didnt. I have spun a bearing now and want to stroke it. I would like to use my 400 dollar rods. maby that will help. And no it isnt a fantasy engine i just dont kno alot with strokers
Old Feb 13, 2005 | 10:16 PM
94 guy's Avatar
Srp 144995
Old Feb 13, 2005 | 11:25 PM
my94blackz's Avatar
Perfect, now to find a really thick head gasket.
Old Feb 14, 2005 | 02:38 AM
my94blackz's Avatar
Well since we found a piston next question is did i mess up this plan by shaving the block the first time? The stock height is 9.0, the setup i cut my deck to was 9.30 then cut .027 and .029, if i went with this piston it would be 8.987. Would the piston stick out ruining this whole idea? I used the stroke/2 + ch + rod length=dh. If none of this made sense im sorry it is very late. If it doesnt least i learned how to calculate deck height.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
