Comp Cams 982 Valve Spring
Old Feb 14, 2005 | 04:12 AM
vette40th's Avatar
I am looking at using this spring, in place of my 941 springs, as I think they are too stiff, and I only take the motor to 6000rpm. But, I have a 525 lift cam, and they , being Comp Cams website, that it is only good for 500 lift. But you look at the specs, and it is installed height of 1.75 and coil bind of 1.135, and that gives you more than a 500 lift cam. The write up shows 500lift, but the spring chart shows 525 lift. Anyone used these?
http://www.compcams.com/Technical/Cu...ML/340-349.asp
valve spring chart, and valve spring srite up for conical #982 about half way down. http://www.compcams.com/Technical/Cu...ML/324-339.asp
My valve springs, 941 Comp Cams, are set at 1.75 height.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
May 25, 2015 09:35 PM
nikolt1
Feb 27, 2015 09:10 PM
