396 LT1 miss at operating temp.
Old May 11, 2005 | 08:02 PM
Aries's Avatar
Ok, well I've only got on problem with my 396. Once it reaches about 190 degrees, the engine begins to misfire getting proressively worse until it simply dies.
Any help or suggestions are of course welcome
Old May 12, 2005 | 10:13 AM
kmook's Avatar
Advanced Tech Moderator
Re: 396 LT1 miss at operating temp.
General engine troubleshooting should be discussed in a Engine Tech forum.
Transferring, thanks.
Old May 12, 2005 | 12:34 PM
sssalah's Avatar
First suspect is the opti.
Old May 12, 2005 | 03:34 PM
Aries's Avatar
Opti and O2's test fine in all areas.
Opti was even pulled apart and checked off the car for any little bits of crud that might fowl the optical sensor.
Old May 12, 2005 | 07:58 PM
1racerdude's Avatar
How long has it been running with this set of heads?
Valve guides to tight maybe?
If-If they are that would hold valves open untill it cools off and maybe enough to stall it if enough valves stayed open.
DirtyDaveW
Dec 1, 2016 05:37 PM
transam_388
Mar 15, 2015 11:53 AM
HCz28
Feb 15, 2015 03:01 PM
