Cylinder head torque question
Old May 12, 2005 | 01:48 PM
BLUETOPTA's Avatar
When using thinner head gaskets, milled heads, or differnt bolts like ARP's
Do you still go by the torque spec in the book or should u maybe torque the head bolts a little less or more?
Old May 12, 2005 | 02:16 PM
OBE1 95Z28's Avatar
Re: Cylinder head torque question
Same torque value. What's more critical is the torque technique, chase the threads in the block to make sure they're clean, lube the underside of the head bolt to prevent binding that can cause false torque values, use thread sealer on the bolt threads, torque them down in the proper sequence in 3 passes...first pass 20 ft-lbs, 2nd pass 40 ft-lbs, 3rd pass final torque value ...60/65 ft-lbs.
Old May 12, 2005 | 08:02 PM
1racerdude's Avatar
If using ARP's use their torque spects and their lube. Follow Chevy's torque sequence.
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Hurin
Dec 13, 2014 07:38 PM
Elcojoe
Nov 17, 2014 10:27 PM
