396 Hp
Old Feb 27, 2007 | 10:54 PM
Bad boy's Avatar
396 Hp
How much horsepower do you think a 396 with AFR 190 heads flowing 297 intake and 200 exhaust the cam is a solid lift 242 254@ 113c/L, I have BBK 58 mm throttle body I have 42 lb injectors I have Th 350 with a Coan 9 inch stall 3500, I have 3.89 gears . The car was tuned locally I think I need more tuning , but what do you guys think it will run at the track I also have a Nx fogger system on the car. The car has hooker long tubes with dual turn downs
Old Feb 28, 2007 | 02:02 PM
Grease's Avatar
What did it make when you had it tuned and why do you think it need more tuning or did you just buy the car and are trying to find out?
There are so many variables, biggest being the amount of nitrous oxide being used
Old Feb 28, 2007 | 10:42 PM
Bad boy's Avatar
ttt
ttt
Old Mar 1, 2007 | 12:37 PM
You need to answer the questions in the first repsonse. With all the uncertainty, it could run anywhere from 475-550 flywheel HP without the nitrous.
In all reallity, you will only know how much power it makes if you put it on a dyno, and you will only know what it runs at the track by taking it to the track.
Old Mar 1, 2007 | 12:38 PM
zx1216's Avatar
maybe 430?? haha, no ideer
TitoPR221
May 26, 2015 12:20 AM
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
whitehooptie
Advanced Tech
Aug 28, 2002 01:51 PM
