383 stroker lt1
Old Dec 25, 2008 | 12:34 PM
  #16
Thumbs down
Originally Posted by MINION
sorry about the lack of information im wanting to shoot for a streetable 425 horsepower. and i do have plans for an sts system in the near future (next eight months or so).
450 HP at the flywheel or at the rear wheels?
also im confused on journal size... i was looking around and pricing differant parts and it mentioned small and large journals do i need to be concerned about this? if so which should i get? do they have to match?
The LT1 mains are 2.45". The 400 mains are 2.65" Crank main journals need to match the block.
as far as my compression goes it is not set in stone. 10:5 i can still run around 12-14lbs of boost w/o detenation problems (or so i understand)
As noted above, 10.5:1 seems a bit high for a blower motor. I've seen some well built, high boost LT1's running in the 9.0 - 9.5:1 range.
Old Dec 25, 2008 | 01:12 PM
  #17
94zgreenmachine's Avatar
Better keep searching your combo. Not much of what you said makes sense. Streetable 425 hp....10.5 :1 compression....STS Turbo..... your all over the place.
Like Dwayne said, look at the heads. You'll find power.
A very good place to start would be the book by hp books:
http://www.amazon.com/Rebuild-Small-.../dp/1557883939
It will give you an overall understanding of the LT1.
Then I'd start by looking at the head/cam package you go after. Once you've settled on those parts the rest (bottom end ) are easy to pick. You can cheap out a few hundred dollars with Lloyds stuff or for a few hundred more get an excellent package from AI. I have had both and I am extremely happy with my AI stuff. Top notch and believe me, there is a difference.
Good luck and happy building!
Old Dec 28, 2008 | 03:27 PM
  #18
MINION's Avatar
boost
well the idea was to keep the boost down around 2-6 lbs unless i was pulling it out to race... i had no plans of running 14lbs all the time on top of that it would be a while b4 i can afford the sts kit and i want to be able to drive it after the motor was built w/o feeling starved for power. i can see the logic behing running 8.5:1 or even 9:1 for a motor dependent on the boost for power. but thats not my intentions. i would like the turbo to be only a power adder... if and when i get around to buying the Remote tubo kit
yes your right i did mean 10.5:1 thank you
Old Dec 28, 2008 | 03:37 PM
  #19
mdacton's Avatar
just buy a compstar rotating assembly
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
