383 stroker bore?
Old Nov 17, 2007 | 01:50 PM
95 Civic's Avatar
383 stroker bore?
I plan on going with a 383 stroker for my LT1, what is the bore for a 383... this is somewhat new to me. help me out.
if there is anything else I need to know, let me know
thanks.
Old Nov 17, 2007 | 02:04 PM
Kwik_Z's Avatar
thanks.
bore is 4.030"
stroke is 3.750"
Old Nov 17, 2007 | 02:13 PM
95 Civic's Avatar
what is stock bore and stroke on a lt1, like i said, this is new to me...
Old Nov 17, 2007 | 02:15 PM
rskrause's Avatar
Moderator
thanks.
It is often said, including by yours truly, that in almost all cases when planning a build go for the most cubes that are practical. That said, you need to keep in mind that the power comes from the heads/cam/induction system and valvetrain primarily. So, these need to be selected to complement the displacement. IF you leave everything else the same, the 383 is still a better choice. It will have ~5% more torque and a bit more hp than a 355 at a slightly lower rpm - all good for the street. But just because it's a "stroker" doesn't mean it will be fast. You still need to concentrate your efforts on the top end if you want results.
A Chev 350 is 4.000"x3.480"
Rich
Old Nov 17, 2007 | 02:21 PM
n2ceptor's Avatar
Rich
Feeling "Confucius" today Rich?????????
Old Nov 17, 2007 | 02:26 PM
rskrause's Avatar
Moderator
Yes, Grasshopper
tapout911's Avatar
rskrause say big cubes dont make big power
Old Nov 17, 2007 | 03:19 PM
1racerdude's Avatar
Ain't what I read!!!!!!!
Big cube small blocks take mega heads and intake to make power as per HP per CID.
Those type of heads(400+CFM) cost 7-8 grand and an intake to match is 'bout 1500.00.
So if ya want a 454 small block bring your checkbook.
A 383 can do fair with a max ported set of stockers.
Old Nov 17, 2007 | 03:31 PM
And there is nothing that requires you to build EXACTLY a 383 (actually 382.67ci). You shouldn't bore the block any more than you need to..... 4.010" (378.88ci) or 4.020" (380.77ci) bores are smart alternatives, allowing the cylinder walls to retain more of their strength, and allowing more meat for a future rebuild. You will never notice the small difference in displacement.
Old Nov 17, 2007 | 10:31 PM
95 Civic's Avatar
well do you think I should just stick with a 355 or go ahead with the 383. My plans are the cc306, ported stock heads, edelbrock air gap intake. all gasket matched, I have 1.6rr, pushrods, springs, etc...
thanks
Old Nov 17, 2007 | 10:49 PM
94sc383's Avatar
what do the heads flow?
Old Nov 17, 2007 | 11:25 PM
rskrause's Avatar
Moderator
thanks
383 IF you are planning on replacing the crank anyway. If you have a stock crank in good condition, stick with it and build a 355.
Rich
Old Nov 17, 2007 | 11:45 PM
95 Civic's Avatar
well people are telling me to just buy a reman crank... so tell me one thing... I there an advantage with a 383 over a 355?
thanks
Old Nov 18, 2007 | 12:38 AM
rskrause's Avatar
Moderator
thanks
Read my first post!
Rich
Old Nov 18, 2007 | 01:52 AM
sbs's Avatar
sbs
I plan on doing a h/c/i, and i've decieded on going with the 847 cam...
Im installing the CC306 in my stock bottom end motor.
I added 1.6 rockers to my stock cam, which added lift to my cam...
what is the STOCK lift for the STOCK springs...
Am i stressing my valvetrain...
Im familer with LT1 cars and performance parts... and ive deceided to do a Heads and Cam set up.... just a few questions...
Where is the benefit in porting your stock heads...
Or which aftermarket heads would you go with...
I think you will have a much better end result if you get a single thread going to discuss your entire engine as a package rather than having all these piecemeal threads...
A bit of searching would also answer most of these questions.
