383-fuel psi & sensor Problems
Old Jan 8, 2004 | 08:21 PM
Supermanx500's Avatar
Wow where do I start. I will start from the begining
I had a Lt1 383 built about 4-5 months ago. I have not gotten it dyno tuned yet, but I got pcmforless ObdI programing done. When I got this done I told him to program it for heads that I didn't end up putting on. So it was running really rich. To fix this problem I planned to take it to the local dyno. The owner told me to get a fuel pressure regulator to help tune it faster. So I did. A local shop put it on today. They tuned it to 45psi which is what they said was stock. black smoke poored into the shop. That is how rich it was running at 45psi. They said that they kepted turning it down trying to get the black smoke to stop. It stopped at 15psi! They said that they had to move it back up to 35psi because 15 was not going to work but that is not normal. They have no idea why it is running like this! they tried to scan my computer and my computer would not talk to theres. When they tried to scan my computer they used OBDII because that is the port that hooked up to the scanner, but I have a vented Opti, 2 o2 sensors, and other OBDI parts. So they don't know what is going on. So my 383 with .556 .576 camed car is running rich at 35psi! NOT Normal! Plus My computer seems to be both OBDi and 2 . They said that obd1 and obd2 have different plug in ports and if obd2 fit in there that is what mine is. That is the least of my worries because my car is running rich at 35psi! I am getting 4.77 miles to the gallon!
Help me! what could this be. Is it the air temp control sensor. because I know when they die the computer is told it is -280* outside and my computer could be trying to compesate for this but then why is they pressure so low?
Old Jan 8, 2004 | 09:10 PM
kmook's Avatar
Advanced Tech Moderator
These problems/questions should be discussed in LT1 Tech, transfering.
Thanks.
Old Jan 8, 2004 | 09:44 PM
Hey **** head these questions/ problems are fine for this forum. What you can't just answer my question? god damn, I swear I hate this damn board, it is like this form is to good to answer it questions.
As for what you said it is a question that protains to this forum. I have a 383 that is having problems. Not just regular problems. Major fuel issues. If you don't want to read this post in this forum then don't but other people might and might be able to help me.
This **** just really pisses me off!
Old Jan 8, 2004 | 11:09 PM
You might want to go back and refresh your memory regarding the conditions you agreed to when you joined this site. Moderators are given the responsibility for determining the correct subject matter in each forum. If you have a problem with the Moderator's actions, take it up personally with him in an e-mail, or send your complaint to the Board owners/Admins.
A post like this has led to the removal of more than one person from this board.
I only read this post because it appeared to be something I could answer, but after seeing your attitude, I'll pass.
Old Jan 8, 2004 | 11:49 PM
Steve in Seattle's Avatar
95's are NOT OBDII... it's an OBDI, but with an OBDII connector. I'll pass on anything else.
Old Jan 8, 2004 | 11:57 PM
BadAssed93Z's Avatar
hey supermax good luck with that
i bet there a hundred people looking up the answer for such a patient gentleman as yourself.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MattFick
Feb 15, 2015 10:16 PM
DarkHorse
Aug 3, 2002 10:17 PM
