383 crank for LT1
Old May 11, 2008 | 07:27 PM
jay97lt1's Avatar
383 crank for LT1
I want build a 383 for my 97 Z I need to know if it is internal or external balenced
Old May 11, 2008 | 08:04 PM
caldercay's Avatar
You have your choice - either way.
Old May 11, 2008 | 08:18 PM
jay97lt1's Avatar
I want to use my M6 flywheel
Old May 11, 2008 | 08:20 PM
94zgreenmachine's Avatar
Internal balance.
Old May 11, 2008 | 10:47 PM
The M6 flywheel (like the A4 flex plate) has a counterweight on it for stock external balance. If you internally balance the rotating assembly, you would have to remove the weight from the flywheel.
Old May 11, 2008 | 11:19 PM
95Blackhawk's Avatar
Do internal balance in case you want to make changes to your flywheel someday.
Old May 12, 2008 | 11:41 AM
WS Sick's Avatar
When you have the rotating assembly balanced, bring the flywheel and dampner, have them balance the crank to them, that way if you need to replace one down the line you can use stock replacement stuff.
Chevyguy358
Jan 28, 2015 08:04 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
