Is there a trick to taking this out?
Old May 30, 2006 | 09:41 PM
Craddock's Avatar
I've scanned my car with Freescan because it is using a ridiculous amount of gas for what running I'm doing, and it came up EGR and right oxygen sensor. So I decide to try the sensor first and go out and buy it. Well I put the car up on ramps and it's sure hard to take this out. I can tell it's messed up cause one of the wires is completely disconnected. The only way I could see doing it at home would be to take out part of the suspension on the bottom. Is there something I'm missing cause usually when I go pay for someone else to do this kind of stuff it comes up on the board like a week later that it's insanely easy if you do this or that. So is there a trick to replacing the right oxygen sensor?
Old May 30, 2006 | 09:52 PM
Pokey's Avatar
Re: Is there a trick to taking this out?
I think I dropped the Y pipe to get a little more room to reach up there.
Maybe the sheetmetal crossmember also. I know I didn't drop any suspension parts.
'94 M6
Old May 30, 2006 | 10:09 PM
An O2 socket helps...
Old May 30, 2006 | 10:29 PM
StephenDeli22's Avatar
Dropping the starter or ypipe on the passenger side would help alot.
Old May 30, 2006 | 11:15 PM
Lees94Formula's Avatar
Its not necessary to drop anything. I replaced mine from the top using an oxygen sensor socket (must have this) and universal joint with a couple long extensions. Mine was rusted in there tight so I let some liquid wrench penetrate it for a few hours before breaking it loose. Its not that hard, you just have to be patient and have the right tools.
Old May 30, 2006 | 11:43 PM
ACE1252's Avatar
Ditto above...wait until it is cold....and a breaker bar is your friend too!
Old May 31, 2006 | 06:38 AM
wrd1972's Avatar
uh-huh
Old May 12, 2008 | 11:46 AM
Turbozombie's Avatar
I have tried using two different o2 sensor sockets, none of them were thin enough to clear the lip on the exhaust manifold where the sensor is mounted. How did you have enough room from the top to move the rachet?
96SilverRam
Nov 20, 2016 11:19 AM
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Darth Xed
Jul 1, 2002 03:22 PM
