306 cam users?
Old Jun 18, 2006 | 08:56 AM
  #46
93yellowta's Avatar
Re: 306 cam users?
I have a cc306 cam... just replaced my junky collapsed comp r lifters... much better... but I did notice something about this cam... I don't have the low end grunt/torque than I did when I had stock h/c.... but when I hit 3500 rpm's it comes alive...
Old Jun 18, 2006 | 09:04 AM
  #47
Bersaglieri's Avatar
Re: 306 cam users?
Originally Posted by Mike96z
cc306 is great but in a stock car, it's not making the power it should, a bit smaller cam would probably make even more power. The reason is if you are pushing so much that your heads can't handle, your actually loosing power, but it will deffinantly give you torque.
Stock car meaning stock longblock or totally bone stock. I'd have to disagree with the claim that a smaller cam will probably make more power. Perhaps if you start talking about the GM847 vs a 248/252 or something, perhaps the power would drop off or be hard to put to good use. But I have never seen a Hotcam, CC305, XE503 or anything that size or smaller dyno with the big boys like the GM847 [357rwhp]. Any its even bigger than the CC306.
-Dustin-
Old Jun 18, 2006 | 10:47 AM
  #48
Heatmaker's Avatar
Advanced Member
Re: 306 cam users?
230/236
Old Jun 18, 2006 | 11:54 AM
  #49
Mike96z's Avatar
Re: 306 cam users?
I've seen numbers...........cc305 vs cc306 in stock applications, the cc305 made more power due to the stock heads, the cc306 made a little more torque.
Old Jun 18, 2006 | 06:00 PM
  #50
rpm4lalo's Avatar
Re: 306 cam users?
I like the 306, I had 4.10's long before I ever had the cam in my M6 TA. Plenty of torque for daily driving.
Old Jun 18, 2006 | 07:28 PM
  #51
Re: 306 cam users?
So you've seen CC305 cars trap 115mph with at or above 350rwhp/350rwtq? I sure havent but I'd welcome any proof. Usually the CC305's are below by at least 10rwhp/10rwtq. The only way I'd could see the CC305 making more is if your were severely under-reving the CC306.
-Dustin-
Old Jun 20, 2006 | 11:46 AM
  #52
AlwaysCode390's Avatar
Re: 306 cam users?
So with the LLOYD E. package you get a portjob and a custom grinded cam right? How much extra is it for him to install your valves/springs/r.rockers, ect? ---
Old Jun 20, 2006 | 12:26 PM
  #53
yotaman96's Avatar
Re: 306 cam users?
Valves and springs will be installed. You will have to install the rockers after you put the heads on.
rideordie
Nov 5, 2019 04:52 PM
QuickSilver02
Apr 7, 2015 11:12 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Kyle@CSS
Sep 14, 2002 04:06 PM
Grover
Jul 25, 2002 11:49 AM
