306 cam users?
Re: 306 cam users?
I have a cc306 cam... just replaced my junky collapsed comp r lifters... much better... but I did notice something about this cam... I don't have the low end grunt/torque than I did when I had stock h/c.... but when I hit 3500 rpm's it comes alive...
Re: 306 cam users?
Originally Posted by Mike96z
cc306 is great but in a stock car, it's not making the power it should, a bit smaller cam would probably make even more power. The reason is if you are pushing so much that your heads can't handle, your actually loosing power, but it will deffinantly give you torque.
-Dustin-
Re: 306 cam users?
I've seen numbers...........cc305 vs cc306 in stock applications, the cc305 made more power due to the stock heads, the cc306 made a little more torque.
-Dustin-
