306 cam users?
Re: 306 cam users?
Originally Posted by 94badrag
A few of you talk about SURGE, enlighten me. What exactly is this?
OK, so i'm learning.Brian
Ryan
Re: 306 cam users?
OK, I do have the M6. So if i get this then you mean under acceleration the the car will surge occasionally instead of ramping up smoothly? What has the cam to do with this? How to prevent this?
Brian
Brian
Re: 306 cam users?
Brian
Brian
Brian
Brian
The surge occurs during cruising speed. For me it was generally occurring under 2100rpm, below 50mph, in between 35-60Kpa (engine load).
Ryan
Re: 306 cam users?
Are the Lloyd Elliot packages a cam AND a head set sent to you , or does he just port your stock heads that you send in?! Seems pricey if he just ports your stockers and hands you a cam, thanks ---
Re: 306 cam users?
The cc306 is going to be lopey on a stock set of heads and manifolds and is a big cam. If you have stock heads etc. cc305 would've been a better choice. Like I had the problem of my engine basically choking off my cc306 so I got ported heads/intake/tb and LT's and it ran fine, little lope could be heard. Now I went to a 388 w/ cc468 which is a good cam for my setup, cam is .584/.579 w/ stock rockers and I'm running 1.6's. Now I just need more fuel so otherwise the cam isnt good for stock applications. A tune may help alittle.
Re: 306 cam users?
I have had my CC306 for four years now and would buy it again tomorrow. Makes plenty of torque and plenty of horsepower. I will be keeping this cam when I switch to ported Trickflow heads later this year.
BTW- this cam works great on my unported factory heads.
Re: 306 cam users?
I to have this cam in my car. I have some GTP heads w/ it. I had the LT4 hot cam at first. I really love the idle, and the cam does have power. I do agree that gears and a good tune are vital.
I don't regret the cam at all!
Re: 306 cam users?
I daily drive my 306 (on a 112). To be quite honest the ONLY reason I got this cam was because I got it cheap. If I was buying brand new I would DEFINATELY go custom grind. But as far as driveability, I have an excellent tuner that works in house at my shop. And my car is as smooth as silk. Its a full weight, a/c, t-56 with 3.42s, lt's and slp 20tl. I have absolutely no complaints for what I have in my car and for the way it runs. Sounds awesome, pulls great even for the stock 135k lower end. All I did to the heads was install new springs, and seals and a resurface. I average 19 around town and so far got a best of 24 on the hwy. Hell I still have the stock clutch in it. I'm not sure what the car weighs (97 hardtop SS) but I haven't done anything to lower the weight (and don't plan too). I achieved what I wanted. A sick sounding, well running car that is decent on gas and I am not afraid to drive to both ends of the country. Rain or snow doesn't matter.
Re: 306 cam users?
cc306 is great but in a stock car, it's not making the power it should, a bit smaller cam would probably make even more power. The reason is if you are pushing so much that your heads can't handle, your actually loosing power, but it will deffinantly give you torque.
Re: 306 cam users?
Re: 306 cam users?
UHHH it was just a question.....I was confused it if came with a set of heads , so I asked. I have heard NOTHING but great stuff about the LE packages, and said NOTHING bad about it myself. Sorry I asked ---
Re: 306 cam users?
