2 questions
2 questions
installing my longtubes this weekend, what brand of manifold gaskets should i use and what type of nuts/bolts/studs should i use on the headers, i want to torque them down enough a couple of times to take care of any leaks that would arise
question 2 is looking at getting a set of roller rockers, crane gold 1.6 rollers, self aligning, what kinda of equipement/accesories do i need to go with these to do it up right and only have to do it once
main idea for me is i want to do a job once, no thought going to price or difficulty, i want to do it right once and not have to worry about it later
Re: 2 questions
I've had good luck with the Mr. Gasket Copper-Seal #7154 header gaskets. Percy's dead-soft aluminum on the collectors if they are flanged. A locking bolt is best, Stage 8 (may be hard to fit the washer against 1-3/4" tubes) or Breslin. Otherwise, the ARP's.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
