march pulley instructions
Old Jul 2, 2005 | 04:57 PM
Brian Sutherland's Avatar
I was wondering if anyone had the instructions for the install I lost mine or knew where I could get some.
Brian
Old Jul 2, 2005 | 06:38 PM
69vette's Avatar
Re: march pulley instructions
what do you need to know about the install. I'm sure someone on here could tell you
Old Jul 3, 2005 | 02:02 PM
does the undrive pulley rep;ace the harmonic balancer on the bottom of the engine?
Brian
Old Jul 5, 2005 | 07:34 AM
ttt
Old Jul 5, 2005 | 02:30 PM
matt65's Avatar
Brian
This is a pretty easy install. What part of the install are you wondering about?
No, on the LT1s (and March pulley) it rides "piggy back" on the stock piece.
Old Jul 5, 2005 | 02:38 PM
OBE1 95Z28's Avatar
Just to clarify, the stock balancer rides piggyback on top of the under drive pulley. The accessory belt needs to line up with the under drive pulley. There should be longer bolts with the kit to mount both pulleys. Make sure the bolts don't stick out and hit your opti when the pulley rotates.
Old Jul 5, 2005 | 02:56 PM
BUBBA's Avatar
I assume that you have the right belt for the 2 pulley system. Also, if you haven't installed it yet, you might have trouble getting the Alternator pulley off and back on without an impact wrench (the pulley tends to turn when you try to remove the retaining nut). JMHO
Old Jul 6, 2005 | 07:41 AM
yes i got the alternator pulley off it was not that easy to get the new one on. But i lost my instructions and just wanted to make sure how the UD pulley goes on.
Brian
G-BODYT56
Jan 14, 2022 11:14 PM
marlar98
Sep 12, 2018 07:18 AM
Novo
Jun 14, 2016 02:58 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
CARiD
Sep 7, 2015 08:21 AM
