2 bolt or 4 bolt splayed caps?
Old Jun 12, 2003 | 11:47 AM
  #16
thewinner's Avatar
see, if i really dont need to spend the money on it i dont want to. i look at derricks car, spraying 175 on a heads/cam stock shortblock for a long time now with nothing gone wrong.
ugghh
Old Jun 12, 2003 | 11:59 AM
  #17
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: The winner
Originally posted by Mr. Z28 73/97
Several things to consider here, first the engine builder with the 406 2bolt, 400's have bigger main caps than all other sbc, so you can get away with that but I doubt 9000rpm from a 406.
Secondly you're planning on NOS right, then without a doubt get the splayed or straight 4 bolt conversion done.
Thirdly go to SDPC.com you can get GM billet splayed caps for $50.00 ea you'll need 3 center and a billet front cap $55.00 best prices going and the best part is with these caps as opposed to some others you will still be able to use your dipstick. With some of the othe caps ( Milodon comes to mind ) you can't get the dipstick past the cap.
why? if anything he'll be revving lower with nitrous
RPMS are the killer here-
a BASIC rule of thumb is-
hp and rpms kill rods
rpms kill crank
heat kills pistons
Old Jun 12, 2003 | 12:06 PM
  #18
thewinner's Avatar
trey you think i'll be ok with just 2 bolt and studs then? i'll probably be revving to 6200 or so? shut the nitrous off at 6k right? window switch from 3-6k?
Old Jun 12, 2003 | 01:13 PM
  #19
Mr. Z28 73/97's Avatar
TreyZ28
Yea rpm is hard on rod bolts and valve springs but hp/tq especially on a stroker with spray is going to be hard om the 2 bolt mains. But the winner will find out when his mains get to moving around under that power and he has to rebuild his motor.
And Nitrous kills everything eventually.
Old Jun 12, 2003 | 01:17 PM
  #20
treyZ28's Avatar
Dont get me wrong-
with enough hp- you can break a crank at 10rpm!
Revving to 6200, from what i've read and my own questioning of expertse when i built my motor-
its not needed
i'm reving to 6700 and im not worried
in my opinion, thats money better spent on a harmonic dampener-
or just get a corvette block or something
Old Jun 12, 2003 | 01:38 PM
  #21
jbird's Avatar
If you've got the money, just get whichever 4 bolt you decide upon and you won't have to worry about it. You would probably be ok, but peace of mind is worth a lot.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
