Hooker catback people inside.
Old Jun 11, 2003 | 10:40 PM
drewstealth's Avatar
I am pleased about the way the system sounds. Because it sounds great. But while driving the car it rattles under the car and it is pretty annoying. It is hitting right where the i-pipe meets the y-pipe. Where it connects the y-pipe is just resting on that black metal bracket that goes under the exhaust. That is where it hits most. But i hear noises from the exhaust hitting from where around the muffler is also. Does anybody else have this or had this problem. How was it fixed. It is so annoying i'm thinking of getting a different catback now and i only had it for 3 weeks.
Old Jun 11, 2003 | 11:13 PM
CrippleFightin's Avatar
I had a problem similar to that but I found out it wasnt hitting anything. The whole exhaust system was shaking because someone welded some of the pipe wrong. It had leaks in it causing this rattling noise. Almost as if a rock was in the muffler or something. That was my problem. Had a guy weld it (who knew what he was doing) and it works and sounds fine now. Hope it helps.
Old Jun 11, 2003 | 11:51 PM
My95Z's Avatar
i don't have problems, my friend did tho, it ratteld on the little brace thing that makes sure the pipe won't fall off. just bend it a litle
Old Jun 12, 2003 | 01:55 AM
So you think it would be okay to bend the brace thing.
Old Jun 12, 2003 | 09:23 AM
RedWolf's Avatar
mine is fine...maybe every once and a while it has a slight rattle where the pipe bends over the upper traction arm when its cold, but thats it. mines not welded at all and i have no leaks.
Old Jun 12, 2003 | 12:55 PM
I beleive mine hits in a couple of spots. But it is just resting on the tunel brace. They bmr sells a aftermarket one. Has anybody used one of these. I was thinking of getting it to see if it had more clearance. So i wouldn't hit.
Old Jun 12, 2003 | 01:55 PM
96 TA's Avatar
I just took the tunle brace off! It started to **** me off so I yanked it. Your pipe will not fall or sag, at least mine didn't.
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
Beave2780
Sep 23, 2015 12:37 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
