2 bolt or 4 bolt splayed caps?
Old Jun 11, 2003 | 09:46 PM
thewinner's Avatar
Should i stick with the 2 bolt caps with ARP studs? or switch to the 4 bolt splayed caps?
This is on a 383 stroker that should be putting out 450+ hp n/a and around 600-650 on nitrous.
it seems to me that the splayed caps would be a good thing to have? they are just so expensive.
will they hold the crank tight under the load nitrous puts on? cause i know it will move with the 2 bolts.....
Old Jun 11, 2003 | 09:50 PM
chevyboy_z28's Avatar
4 bolt hands down, not up for discussion, not debatable...the end!
Old Jun 11, 2003 | 09:53 PM
rskrause's Avatar
Moderator
Some engine builders question splayed vs. straight 4-bolt cpas. But at that hp level you do need a 4-bolt cap, IMHO.
Rich Krause
Old Jun 11, 2003 | 09:55 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
personally i think RPMS are more stressful than power output- well thats what it seems like anyway. Use ARP fasteners no matter where you go with it
Old Jun 11, 2003 | 10:01 PM
thewinner's Avatar
block is hottanked before machining correct? cause you ahve to have the caps to align hone it right?
Old Jun 11, 2003 | 10:09 PM
RCF925's Avatar
chevyboy_z28, What he said
Old Jun 11, 2003 | 10:14 PM
thewinner's Avatar
who makes the best cap for the money and how much is machine work usually go for?
splayed or straight better?
Old Jun 11, 2003 | 10:18 PM
heres a good set http://www.racenet.net/eng/oliver-caps.php but i wouldnt buy em from racenet ive heard bad things about them.
Old Jun 11, 2003 | 10:21 PM
treyZ28's Avatar
dude, your going to break a crank before you even break a regular 4 bolt main. Billet splayed 4 bolt mains are overkill. spend you money elsewhere
Old Jun 11, 2003 | 10:41 PM
thewinner's Avatar
is the machining cheaper and the parts cheaper on a straight 4 bolt main? i assume it is since its straight holes not crooked ones LOL
Old Jun 12, 2003 | 12:03 AM
yorkie's Avatar
I have a set of new caps (nodular)....
these are for a 2 bolt register block (no machining required) will require a line bore, as any 2-4 bolt will, have a set off a regular 4 bolt main bolt too. Pics too.
Eric
Old Jun 12, 2003 | 08:34 AM
Smoke T/A's Avatar
Re: I have a set of new caps (nodular)....
Eric
A line bore is about $300-450 + another $300 for the drilling of the outer 2 holes. IMHO not worth the money you need a stronger crank before you should worry about the mains. I have seen the 2 bolt with arp studs hold up to about 700 rwhp with out any problems but the crank was a diffrent story(scat 9000).
Old Jun 12, 2003 | 10:43 AM
thewinner's Avatar
Just called up the machine shop, and he told me that i really didnt need it. He runs his 406 sbc all the way up to 9200rpm with 2 bolt mains and studs.
Old Jun 12, 2003 | 11:29 AM
Mr. Z28 73/97's Avatar
The winner
Several things to consider here, first the engine builder with the 406 2bolt, 400's have bigger main caps than all other sbc, so you can get away with that but I doubt 9000rpm from a 406.
Secondly you're planning on NOS right, then without a doubt get the splayed or straight 4 bolt conversion done.
Thirdly go to SDPC.com you can get GM billet splayed caps for $50.00 ea you'll need 3 center and a billet front cap $55.00 best prices going and the best part is with these caps as opposed to some others you will still be able to use your dipstick. With some of the othe caps ( Milodon comes to mind ) you can't get the dipstick past the cap.
Old Jun 12, 2003 | 11:30 AM
Phatcaprice's Avatar
This is what I've heard. The reason they use 2 bolt caps is because they are cheaper to make and use nickel and are really just as strong as a regular 4 bolt main. Any truth to this? Also, if you need 4 bolt mains to hold down a crank that is trying to bust out of the block, I'd think you have problems elsewhere. Unless you're pushing an 800hp sprint car motor, why bother?
