1994 lt1 rebuild
Old Mar 23, 2009 | 06:32 PM
mel0n666's Avatar
Cool 1994 lt1 rebuild
Hi, i posted before saying that my eninge had a knock and whatnot and i am now very sure it is a main bearing so i am defonitially rebuilding this thing.
just for reference it is a 1994 lt1 from a camaro z28 with the stock transmission however it was just rebuilt by the owner before me im assuming it was a stock rebuild. also the car has 172k on the body and engine. here is my question. since summit doesnt offer a full rebuild kit that includes piston rods and a crank i am just gunna pick parts out of their kit that i need and i am getting an eagle rotating assembly from jegs.
so on jegs there are 2 options an i dont know which one i will need there are some small differences between the 2 kits like one is 5cc and the other is 10cc so i was wondering if somebody could clear up what one i will need for me.
#1 http://www.jegs.com/i/Eagle/356/B13402L/10002/-1
#2 http://www.jegs.com/i/Eagle/356/B13403L/10002/-1
also i was wondering if there was any difference between whats in these kits other than the stuff i wont need because the piston heads/ rings/ ect come with the eagle kit.
http://store.summitracing.com/egnsea...=KeywordSearch
i am ordering everything from summit except for the heads/ rings or whatnot as i stated earlier. i will still be buying gaskets i was just wondering if anything varies that i should know about.
here are other things im getting for this rebuild let me know if im missing anything.
http://www.sparkplugs.com/more_info....5874&pid=27490
http://www.jegs.com/i/BBK/129/1567/10002/-1 (cause headers are easier while engine is out)
http://www.elliottsportworks.com/lt1.html (getting the le1 kit with these cams : 226/230 .565/.565 111 LSA. - 1900-6200 RPM
NON-EMISSIONS version of 223/230 cam mentioned above. Mild to choppy idle. Good HP/TQ through out and a very usable power band. Best choice for "most people" using stock bottom end. Minimum 2800 stall and 3.42 gears for B body. Comparable to Comp 467 XFI cam.)
i am also getting the stock gm lifters because from what i have heard they are one of the best.
thank you all for your time and help in advance i really appreciate it.
Old Mar 23, 2009 | 07:46 PM
JooneJune's Avatar
I may have missed it but are you doing bearings too? Cam Rod Main? I used Clevite 77 Nascar series bearings for my rebuild.
Not a fan of BBK headers, I've always liked Pacesetter LT's best bang for the buck.
Old Mar 23, 2009 | 07:54 PM
mel0n666's Avatar
yeah the summit pack comes with bearings. ill look into those headers .... not looking to spend too much just looking for something budget thats better than stock
Edit: so i am kinda licking these seeing as they come with gaskets and everything and are cheaper but i am looking for any other opinion on the headers situation. try and keep it under $400 and if any1 else thinks these are better than the bbk let me know
http://www.jegs.com/i/Pace+Setter/766/70-1335/10002/-1
again thanks i am all open to suggestions and ect.
Old Mar 23, 2009 | 08:36 PM
bombebomb's Avatar
Pacesetters are a good budget header, many of us run them. However getting non coated headers will insure a rusty life and they will look awful after only a short amount of time. I do not know BBK's myself.
Old Mar 23, 2009 | 09:16 PM
mel0n666's Avatar
i read up a bit and im going to go with the bbk. the bbk has better performance and i think im going to buy it from summit. also i meant to post the chrome headers. but anyways im buying the bbk ones. also im still wondering if any1 knows what kit i need from jegs for the rotating assembly.
Old Mar 24, 2009 | 12:26 AM
dStruct's Avatar
Have you looked at Advanced Induction yet? They make some pretty sweet little LT1 rebuilds.. I'm considering going with one of their LT1 "packages" when I get ready to do my 383 swap.. You might want to take a look.
I hope it's not against the rules to post a link like this but http://www.advancedinduction.com/
Old Mar 24, 2009 | 02:16 AM
tbkdkc's Avatar
dont get bosch plugs.. stick with ac delco or ngk tr55
Old Mar 24, 2009 | 06:02 PM
mel0n666's Avatar
i thought bosch was good
also advanced induction is too expensive and i know that L. Elliot makes good stuff.
Old Mar 25, 2009 | 09:36 AM
camarobird92's Avatar
If you are gonna buy a complete rotating assembly anyways, why not go with a 383?
Old Mar 25, 2009 | 12:36 PM
87bandit's Avatar
^+1
if you stick stock cube might as well just buy one of those $9xx GM shortblocks, only difference with a new RA between 350/355/383 is you have to clearance the block
the ealge kit comes with clevite bearings and rings
Old Mar 25, 2009 | 01:02 PM
stantheman601's Avatar
You can get LT coated pacesetter headers from herronperformance.com for $385 shipped. that comes with gaskets and o2 extensions. Definitely best bang for your buck and they are well built. and if i were you, i would put back in the stock o2 sensors until your coated hearder break in then swap them out for a better set, most prefer ac delco. coated headers will mess up o2's until they cook (thats the only word i could think of to describe it), so you dont want to buy new ones jus to mess them up in 500 miles.
Old Mar 25, 2009 | 01:40 PM
mel0n666's Avatar
thanks for the advise but i done see any difference between the pacesetters and the bbk honestly.
also i am pretty sure that i couldnt find any gm shortblock for only $900 ish. also i looked into doing a 383 but i dont really want to rip apart my tranny.
just an fyi this isnt a track car its a daily drive car and i might take it to the drags a few times to see what i can run also my budget is around $3000. i found a local machine shop that the guy says i might be able to get away with only $300 for what i need but if it might cost about 500.still he thinks it will prob be like 300.
if i did a 383 it would cost me 900 for the rotagting assembly i think i would also need different head gaskets and i would need to spend an estamated $700 at the machine shop instead of 300 so that is something like $1k more when u add it together with the head gasket.
so im doign either stock or 355 right now.
Old Mar 25, 2009 | 06:26 PM
mel0n666's Avatar
if these are the ones you were talking about i would need to bu the y pipe as well. so i dont see how it is the best value. unless i could just use the stock pipe that is there or is this pipe better in some way?
https://securehost98.hrwebservices.n...&productId=210
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Nov 27, 2014 09:41 AM
Dr. Weir
Aug 2, 2002 02:36 AM
