head bolt sealant?
Old Mar 24, 2009 | 10:36 PM
udlose94z28's Avatar
head bolt sealant?
ive heard all kinds of different stuff to use on these bolts... which is the best way to go.
Ive bought the arp head bolts with the loose washers and was gonna torque them to 85 foot pounds using permatex high temp thread sealant #80632 and 30 wt oil on the heads and washers... anybody see any problems with this??
ive got the sequence and everything imma go 3 passes 45 65 85 maybe? any advice??
Old Mar 24, 2009 | 10:58 PM
Stl94LT1's Avatar
85 lb/ft sounds kind of high. Pretty sure I torqued mine to 70 lb/ft.
Old Mar 24, 2009 | 11:06 PM
65 is the stock torque. ARP may have a different spec, but 85 sounds high.
http://shbox.com/ci/head_assy.jpg
Old Mar 24, 2009 | 11:44 PM
87bandit's Avatar
my ARPs were 75ft/lbs
there's a piece of paper inside the bolt box that tells you the specs
Old Mar 25, 2009 | 12:44 AM
MachinistOne's Avatar
Permatex #2 non-hardening is the best thread sealant you can buy for this application.
Stick to 65-70 lbs with the head bolts - going higher could end up with threads pulling out of the block as that is where the stress is being applied unlike a stud where you are turning the nut on the top side.
Are these the #234 pro series bolts?
Old Mar 25, 2009 | 01:27 AM
ACE1252's Avatar
I disagree on this.....Permatex #2 is a gasket sealant not thread sealant. Look at permatex's suggested application....
http://www.permatex.com/products/Aut..._2_Sealant.htm
.......oil pans and valve cover gaskets. I have read of many complaints about #2 leaking with head bolts.
I think this is the stuff he needs.....I've never had it leak on me.
http://www.permatex.com/products/Aut...ad_Sealant.htm
Permatex does list head bolts as an application. 24 hours min for cure....72 for full cure.
Old Mar 25, 2009 | 01:39 AM
ACE1252's Avatar
Head bolts are not listed when looking at the data sheet....however temperature sending units are...so you may be okay, but I don't know. I would use what I listed in my previous post.
Old Mar 25, 2009 | 02:01 AM
That's fine....personally I been using it for this application for over a decade, other machinist's I know personally have used it for longer than that after using specialty thread sealants and silicones - this is the best stuff.
Old Mar 25, 2009 | 07:55 AM
That's what I use for thread sealant on the engine.
Old Mar 25, 2009 | 04:46 PM
i bought that stuff, its pretty gooey is it black? i put one head on today, everything went sound... how much of that stuff do you use on the thread.. all of the thread?
Old Mar 25, 2009 | 04:57 PM
The stuff above is white. You only put it on a portion of the threads.
Old Mar 25, 2009 | 07:16 PM
ACE1252's Avatar
Did you buy Permatex #2 or Permatex High Temperature Thread sealant?
Old Mar 25, 2009 | 07:46 PM
i bought permatex no 2 non hardening pliable sealant.. it said sumthin like form a gasket on it but used on threads, it was in a white container but the material itself was black
Old Mar 25, 2009 | 08:01 PM
Just spread some around half the threads or so, if you're unsure - more is better than less and it will only look excessive to the next guy taking it apart.
Old Mar 25, 2009 | 08:02 PM
ACE1252's Avatar
10-4. Good Luck!
