motor buildup questions
Old Sep 23, 2003 | 12:20 PM
will62085's Avatar
i have a couple questions on a motor buildup im planning...
i want to use cc306, 6 inch rods, and about 11.5 CR...i want it to run on 93 octane...is this possible with 11.5CR?...if not, whats max CR with 93 octane?
also, which heads would yall recomend for that setup?...im leaning toward some AFR stage 2 heads...but i really dont know a whole lot about lt1 heads
also, little off topic...is a stock lt1 hydraulic roller?...if so..all cams for it are either solid roller or hydraulic correct?...the cc306 is HR?...thanks alot guys
Old Sep 23, 2003 | 12:28 PM
i387's Avatar
Re: motor buildup questions
Originally posted by will62085
also, little off topic...is a stock lt1 hydraulic roller?...if so... the cc306 is HR?
Yep. The stock LT1 is hydraulic roller. The CC306 is
hydraulic roller as well.
I don't know about the rest of your stuff though.
Old Sep 23, 2003 | 01:34 PM
SStrokerAce's Avatar
You can run more or less compression based on the cam.
How many cubes are you looking at here? What's the rest of the setup?
Kind of need to know what kind of budget to recomend heads and other parts.
Bret
Old Sep 23, 2003 | 05:31 PM
will62085's Avatar
stock crank .030 over...so a 355 ...im looking at about $3500 max...ide like to stay under 3k though...its got jet hot long tubes, i can get it programed after the build up...cc306 cam, 1.6RR...staying hydraulic roller...afr stage 2 heads i think...dunno yet about the heads...6 inch rods...what else do you need to know?
Chris Anderson
Jan 27, 2015 08:30 AM
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ChrisFrez
Nov 23, 2014 10:33 AM
