100K plus miles, What OIL?
Old May 19, 2008 | 11:26 AM
  #31
MaximumJavelin's Avatar
I've got about 110k on mine, I run Royal Purple 5w30. I used 5w20 previously but it's just too thin for summer use. Idling in traffic when it's 90* out my oil pressure would plummet towards 0 at an alarming rate. Then of course if you put a heavy summer weight oil in, once it gets cold oil pressure skyrockets and likely is bypassing the oil filter, which I don't particularly like. If you change your oil every 6 months or so it works out pretty well, 5w20 for winter use and 10w30 for summer.
Old May 19, 2008 | 02:31 PM
  #32
Mtxz453's Avatar
i started using mobil 1 synthetic and my car started leaking more.
Old May 21, 2008 | 02:22 PM
  #33
slomarao's Avatar
I figured that switching to syn. now would make my leaks worse and larger. Thats one of the reasons why i wouldnt run it. What conventional oil were you running(mtxz)?
Old May 21, 2008 | 10:28 PM
  #34
joe93z's Avatar
5-30 syntec kn filter..i change the oil twice filter once..works fine for me
Old May 21, 2008 | 11:53 PM
  #35
FirebatLT1's Avatar
I use KN 3002 Filter - holds an extra 1/2 quart and i think has the anti-drainback valve. And its longer so its easier to get out or easier to reach. Three advantages over the KN 2002. Use Mobil 1, 10-30W. No leaks. I replaced all of the seals/gaskets on my 100,000 mile stock LT1 though but didn't have much of any leaks before I replaced all that.
I have always changed both filter and oil every 2000 miles or 3-4 months on whatever vehicle I own that I drive, unless it hardly gets driven(something like 200 miles in 3 months) or if it is put in winter storage.
Old May 22, 2008 | 01:13 AM
  #36
Bersaglieri's Avatar
Synthetic oil is great, if it leaks, fix the leak. Use NAPA Gold filters and you'll be fine.
-Dustin-
Magenta_Hearts
Mar 29, 2017 08:54 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Catmaigne
Dec 25, 2014 12:16 PM
