100K plus miles, What OIL?
I know the threads about which oil you use have been beaten like a dead horse, but what about us guys with 100k plus?
i run 10w-40 winter, 10w-30 summer.
Just looking to see whats popular?
So everybody who has 100k plus miles please post up.
i was told to by this old time racer. Ive been doing to so for the past year and a half. So far the bottom end has been bulletproof. get good start up pressure and wot pressures after its warm. You think i shouldnt?
To answer your question, there is probably no reason to change oil type just because you've clocked over 100,000. There may be some advantage to going to one of the oils, blended for high mileage cars. It is a good idea if you have notice a slight decrease in oil pressure over the years. In this case going from a 10W30 to a 10W40 may help, and certainly is not going to hurt.
Changing your oil seasonally is also probably not necessary. But again won't hurt.
However you are susposed to go from a 10W30 to a 5W30. Or from a 10W40 to a 5W40, summer to winter. Changing the high end, 30W or 40W has NO effect on the engine during start up. The idea being to have a lower viscosity oil, in the winter, during start up.
