Trick flow vs. AFR heads
Old May 20, 2008 | 06:26 PM
HULK_LT1's Avatar
Post Trick flow vs. AFR heads
Hey guys need some help kinda new to the game but im addicted to my z now and well its all up hill now, i was wondering what heads would be better to replace stock heads either trick flow or arf heads if any one could help already have mild can straigh pipe with cut off, headman headers, jet chip, air foil, moroso cold air, intake, performance Mass airflow sensor, elbow, ud pulleys, thinking of porting my tpi and tb and going with (3.73 or 4.10?) have 100 shot of juice but don't really want it probably turbo instead with 5psi well u guys let me know if u have info for me please that i can help or doing wrong....
Old May 20, 2008 | 06:31 PM
ShownomercyZ28's Avatar
Get your stock heads porter by Lloyd, I think they will flow better than the AFRs out of the box but the AFRs have more potential for porting.
Old May 20, 2008 | 06:36 PM
HULK_LT1's Avatar
to what size do you think would be a good port?
Old May 20, 2008 | 06:45 PM
caldercay's Avatar
Ai.
Old May 20, 2008 | 06:46 PM
MeanGreen97Z's Avatar
Most heads in the 180cc range are good for most applications. 200cc heads from AI seem to be top dog right now though.
Old May 20, 2008 | 07:01 PM
HULK_LT1's Avatar
thanks i appreciate the help
Old May 20, 2008 | 11:04 PM
SS MPSTR's Avatar
I'd personally recommend AI, but there is a new sponsor on here who could probably make you a great deal on a set of ported stockers with a cam. See Port Masters - they have a few threads on here and elsewhere. Might be worth a try.
Old May 21, 2008 | 01:36 AM
SuperbeaSSt's Avatar
Okay few things here, first what size tb? Do you have a manual or auto? If its an auto you want a nice small diameter stall(9.5", not 12") (2400-3600). Also what size cam? specs....? If you want some idea of power with stock Trick Flows check my sig.
Although when I get back to the shop and get it back on the dyno after a few upgrades, I'll post new numbers. However as you can see the power is not that high considering the mods. There are ppl on here with just really good top end parts making the same or MORE power. SO I think you're hp goal is doable, but the TUNE is huge on that with your budget in mind. Like ppl said above Lloyd Elliot does some good porting for stock heads as well as Advanced Induction too, I sold a pair of ported stockers from Lloyd that flow better than my stock TFS.
Old May 22, 2008 | 04:17 AM
awdfun's Avatar
I got a set of new Trickflows from HiFloEngines in Lakeland FL for around the same price as a set of le3 heads
215cc Intake Ports
Lift Intake Exhaust
.100 80.01 68.2
.200 142.9 131.2
.300 239.3 150.7
.400 256.8 210.4
.500 284.6 220.1
.550 300.01 234.6
.600 315.2 248.3
parkers Z28
Mar 11, 2016 08:14 PM
BinkZ28
Apr 20, 2015 09:10 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MadMav
Feb 6, 2015 11:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
