Which 1.6 Rockers are you guys using?
Old Apr 2, 2006 | 09:56 AM
user 647483's Avatar
Are most people running stock studs or upgrading to larger ones?
NSA+guideplates or SA?
Old Apr 2, 2006 | 10:03 AM
luckyou03's Avatar
Re: Which 1.6 Rockers are you guys using?
I'm running arp stock sized studs with NSA 1.6 RR and GM guideplates.
Old Apr 2, 2006 | 10:08 AM
sabre81's Avatar
same.
Old Apr 2, 2006 | 10:14 AM
30696bird's Avatar
Look in sig.
Old Apr 2, 2006 | 10:43 AM
FastZinTennessee's Avatar
GMPP 1.6 self aligning, stock studs.
Old Apr 2, 2006 | 11:38 AM
firebirdStud's Avatar
was using self aligning GMPP 1.6 roller rockers out of the hotcam kit, 3/8 stud. Selling that and upgrading to pro mags, 7/16 stud, and guideplates. From what I hear should be the cat's @ss.
Old Apr 2, 2006 | 12:26 PM
12SCNDZ's Avatar
Comp non self-aligning Pro Magnum 1.6's with ARP 7/16" studs, and GMPP guide plates.
Frank
Old Apr 2, 2006 | 12:28 PM
91Z-28's Avatar
I see a lot of you guys are running the 1300 series Pro Magnums, what are the advantages of the 1100 series "Hi Tech" stainless rocker arms? They sure cost a lot, but I'm seriously considering buying a pair.
Old Apr 2, 2006 | 01:03 PM
LT1Mike's Avatar
hmmm i wanted to throw on some 1.6 rr on my camaro after header install... who has the best pricing nowadays? Self Aligning is the way to go to i here... right?
Old Jun 29, 2006 | 03:33 PM
LT1Mike's Avatar
I got these ordered.... What else do I need?
1.6 Roller Rockers GM PART # 12370839
LT4 Spring GM PART # 12495494
Valve Spring Cap Kit, LT4 GM PART # 12495492
Engine Valve Spring Cap Key GM PART # 12495503
Valve spring shims GM PART # 10212809
3/8 Stud Pkg GM PART # 12371058
Do i need guideplates?
Old Jun 29, 2006 | 04:07 PM
NSA = Non-Self-Aligning (need giudeplates)
SA = Self-Aligning (don't need guide plates) <----- yours
12370839 Aluminum Roller Rocker Arm 1.6:1 Ratio
These small block 1.6:1 ratio aluminum rockers are similar to the rockers used in the 1996 Corvette LT4 engine, except the trunnions have been machined for early model 3/8" rocker studs. These kits of 16 rockers include nuts and instruction sheets. They are self-aligning style rockers with washers between the rollers and the rocker body for improved wear characteristics. By reducing the length of the rocker stud slots, it improves the stiffness by 30% over comparable aftermarket designs. These rockers will accommodate up to .575" valve lift. One of the main advantages of these rockers is about 2 lbs-ft in rotation torque, which provides a quieter idle.
Technical Notes: When using a high lift camshaft, be sure to check for valve spring coil bind, retainer to seal clearance, and piston to valve clearance. When using valve covers with drippers, it may be necessary to remove them for proper rocker arm clearance. When using on cast iron head check for adequate pushrod clearance. Cannot be used on ZZ3 engines with orange valve springs.
Old Jun 29, 2006 | 05:07 PM
Another Red Z's Avatar
Crane Gold Race , 3/8 stud , NSA with GMPP guide plates and comp pushrods.
Old Jun 29, 2006 | 10:04 PM
LT1Mike's Avatar
So then... I got everything I need? I heard 94s had hardened pushrods so no need for those.... what else do i need? or did my list cover everything
Old Jun 29, 2006 | 11:23 PM
LT1Mike's Avatar
ok one last thing.... well three...
1. Should i order another set of shims? they only come with ten... wondering if i need more... and oh...
2. does it look like i covered everything...as far as things i need for 1.6rr to run fine?
3. 3/8 are stock studs to right? sorry guys...
Old Jun 29, 2006 | 11:48 PM
You can run the stock studs if you are running the GMPP 1.6 SA rockers.You only need to upgrade the studs when running NSA rockers.As you need shoulder on the studs for the guide plates.One package of shims should be fine.
