Which 1.6 Rockers are you guys using?
Old Jul 5, 2006 | 02:53 PM
  #46
user 647483's Avatar
Re: Which 1.6 Rockers are you guys using?
Originally Posted by yournamehere
Not meaning to hi jack the thread,.....
That's ok, we can share
is the stock ratio 1:50 ?
Yes 1.50:1
I'm going to pull the heads on my '96 LT1 after a head
gasket mis adventure and I'm thinking check for flatness, clean up valves,
maybe 1:60 for a little more umph ?
Worth it ?
1.60:1
Absolutely! It's a great mod
Assuming you've done some of the other basic bolt ons (CAI, catback, headers, etc ...)
It was next on my list, then I decided to do heads/cam while I was at it.
My Camaro has been sitting for over a year while I
recovered from a motorcycle accident and saved money to work on it.
I don't want to cut corners, just make it safe and fun.
Old Jul 5, 2006 | 04:17 PM
  #47
Bersaglieri's Avatar
Dont forget to match the rest of the valvetrain to the higher ratio rockers. The LT4 spring kit it a great buy.
1.6:1 and 1.5:1 is the ratio not 1:50, not sure if that was a typo.
If you have the heads off, I'd get them ported and polished, send them out to LLoyd Elliot or something and have him setup your valvetrain and get a cam.
-Dustin-
Old Jul 7, 2006 | 12:25 PM
  #48
yournamehere's Avatar
More thread sharin'.....
My Z is a '96 with CAI, a Flowmaster aftercat and tune by ProDyno in
Tempe, AZ.
With good air one night I ran a 13.10 @ 101 mph at Speedworld. I was
a happy son of a gun, that close to the 12's
Bottom line is temp gauge was probably running low, and the car got
hot and sprang a major coolant leak on the expressway, then head
gasket let go. I'm just about ready to take it apart, first thing is these
cars are a challenge to wrench on. With 94,000 miles I'm thinking
head gaskets, valve job, and cooling system. ( water pump, radiator,
have fans and temp guage checked for proper operation) Go faster
stuff, while wanted, maybe out of reach for now.
Except.
I keep thinking, man, I'll have it apart. Drop in some 1.6 RR's, then
the manifolds will be out, how about some smog legal long or mid tubes ?
On and on it goes....
Thanks !
Old Dec 14, 2010 | 01:57 AM
  #49
Moved up to Ultra Pro Magnums this year, yet to fire the motor, but they are pretty
-Dustin-
Old Dec 14, 2010 | 12:19 PM
  #50
Queens94z28's Avatar
Ultra Pro Mags as well. Been working great for the past year.
Old Dec 14, 2010 | 12:20 PM
  #51
19z28camaro02's Avatar
Went Ultra's myself, they are pretty.
Old Dec 14, 2010 | 12:56 PM
  #52
Blackthunder50's Avatar
My current setup:
-Scorpion 1.6rr NSA
-Trickflow 7.2" Hardened Pushrods
-Trickflow Guideplates
-ARP 7/16" Studs
I adjusted these during the initial break in and then readjusted after about 25 miles. I checked them recently and they're all on the money. They fit under the stock valve covers and are pretty quiet.
Old Dec 14, 2010 | 03:08 PM
  #53
TransAm2k4's Avatar
I had Pro Mag 1.52 and now moved to 1.6 Ultra-Gold which are the new Aluminum ones from comp cams. Does really look too pretty to install... Might install my Pro Mag and keep the Ultra-Gold's on my desk... Just Kidding!
Old Dec 15, 2010 | 09:46 AM
  #54
rpmatredline's Avatar
I recently did my top end and Lloyd suggested the SA Comp Ultra promags and i got the Manley 3/8 cro-mo pushrods. so far so good.
oldschool
Feb 9, 2016 09:21 PM
Red_94Formula
Jan 22, 2015 12:17 AM
Red97LT1
Aug 7, 2002 05:45 PM
