Which 1.6 Rockers are you guys using?
Old Jun 30, 2006 | 07:44 AM
  #16
Will84's Avatar
Re: Which 1.6 Rockers are you guys using?
Originally Posted by 12SCNDZ
Comp non self-aligning Pro Magnum 1.6's with ARP 7/16" studs, and GMPP guide plates.
Same here
Old Jun 30, 2006 | 09:30 AM
  #17
user 647483's Avatar
Originally Posted by Will84
Same here
Thanks guys, that's what I ended up buying.
Old Jun 30, 2006 | 10:15 AM
  #18
Mtrhds94Z's Avatar
Originally Posted by LT1Mike
So then... I got everything I need? I heard 94s had hardened pushrods so no need for those.... what else do i need? or did my list cover everything
Since you have 'self aligning', there's no need for hardened pushrods anyway..
Old Jun 30, 2006 | 10:29 AM
  #19
MEAN LT1's Avatar
I see some of you are running the GMPP 1.6rr sa. Do some of your rocker arms sit on the retainer?. Some of mine do and some dont. Ive tried cranes 1.6rr sa also and they do the same thing. Are any of you have the same problem?. Im going to switch some pro mags with a slimmer arm and that she be ok I hope.
Old Jun 30, 2006 | 10:51 AM
  #20
ulakovic22's Avatar
I had the GMPP Hot Cam rockers when I got my LE1 package and the shoulders rubbed badly. I switched to Pro Mag SA and haven't had a problem. You will be fine with those I'm sure. You just have to take out the valve cover webbing if you haven't already.
Old Jun 30, 2006 | 11:35 AM
  #21
MEAN LT1's Avatar
Ok, so it seems im not the only one with this problem.
Old Jun 30, 2006 | 12:30 PM
  #22
LT1Mike's Avatar
awww crap... so i shouldnt get them then? i was planning on having a mechanic whos installed rockers b4 install em too.... i was told there not a bad rocker.. and well i already purchased them....
webbing?????
Old Jun 30, 2006 | 03:03 PM
  #23
MEAN LT1's Avatar
webbing?????
Not saying you shouldnt get them but be forwarned that this may happen to you too. I had the same thing happen on two seperate heads with those rockers. Id get some promags.
Old Jun 30, 2006 | 03:13 PM
  #24
The crane SA 1.6s worked nice on a previous project car.
I went with NSA promags this time around because I used a more agressive cam.
Old Jun 30, 2006 | 05:10 PM
  #25
LT1Mike's Avatar
if the pros work better then i will return these and get those then.... as long as i dont need to buy anything else i will get those.
does this all sound good? :
16 Comp Cams Pro-Magnum Self-Aligning Roller Rocker Arms, 3/8" stud, 1.6 Ratio
LT4 Spring GM PART # 12495494
Valve Spring Cap Kit, LT4 GM PART # 12495492
Engine Valve Spring Cap Key GM PART # 12495503
Valve spring shims GM PART # 10212809
3/8 Stud Pkg GM PART # 12371058 (doubt i need these i was told)
Old Jul 1, 2006 | 04:53 AM
  #26
LT1Mike's Avatar
Are the 1.6 GMPP that ****ty of a rocker? i mean ****.. if the hotcam uses it.. and theres not much trouble with those.. i thought this would be a good rocker.. since i dont plan on camming this car... got other things to worry bout... I just want a I/H/E, and maybe a little juice at the track... would the 1.6s suit me good? Even if they rub... is it that bad of a thing? I thought most rockers do though?
Old Jul 1, 2006 | 06:10 AM
  #27
Joe B's Avatar
Nothing shoud EVER be allowed to rub in that area of a valvetrain(major problem waiting to happen with all the additional harmonics and stress it could cause on parts)........And In my opinion , even for your described useage, I would return what you got for the 7/16 size comp promags(They're a much stronger and better designed rocker) I would also spend the 25 bucks and pick up the larger ARP 7/16 studs to go with them....small price to pay for a ton more strength, but thats just me......good luck with it......
Old Jul 1, 2006 | 06:55 AM
  #28
cpformula's Avatar
1.65 Morels here... (but a solid roller setup)
Old Jul 1, 2006 | 09:57 AM
  #29
Mtrhds94Z's Avatar
I have the Crane Gold 1.6's with LT4 springs and retainers, and they don't rub the retainer at all..
Old Jul 1, 2006 | 04:46 PM
  #30
LT1Mike's Avatar
Whats the part number for GM Retainers? and ****.. if i install them fine... im sure they'll work good... dont alot of people use the cranes
