Which 1.6 Rockers are you guys using?
Old Jul 1, 2006 | 05:36 PM
  #31
Mtrhds94Z's Avatar
Re: Which 1.6 Rockers are you guys using?
Originally Posted by LT1Mike
Whats the part number for GM Retainers? and ****.. if i install them fine... im sure they'll work good... dont alot of people use the cranes
The 'cap kit' and 'spring cap keys' p/n's in your above post are correct..
Old Jul 2, 2006 | 03:46 AM
  #32
LT1Mike's Avatar
so am i ready to install these then? everything seem covered? did i get the retainers... i didnt see that on my list.. im so tired.. lol I want everything possible so i get a nice clean install... do i got all my parts down?
Old Jul 2, 2006 | 09:55 AM
  #33
stereomandan's Avatar
Originally Posted by 12SCNDZ
Comp non self-aligning Pro Magnum 1.6's with ARP 7/16" studs, and GMPP guide plates.
Frank
I third that, or fourth... whatever it's up to now. If you are going to do rockers, you may as well go with larger studs since they don't add much cost.
Also, added to that list should be hardened pushrods, and LT4 springs.
This setup has been awesome so far.
BTW, make sure you get GM guideplate part # 14011051. They are the correct guideplates for the LT1. You can see pics of the stuff in my sig.
Dan
Old Jul 2, 2006 | 02:35 PM
  #34
Mtrhds94Z's Avatar
Sorry, I should have said :
The 'cap kit' is the RETAINERS,and 'spring cap keys' are the LOCKS.. just different terminology..
The p/n's in your above post are correct..
  #35
LT1Mike's Avatar
sweet... then i got everything needed to run em huh?
Old Jul 2, 2006 | 04:45 PM
  #36
Bersaglieri's Avatar
Frank
Yup.
-Dustin-
Old Jul 2, 2006 | 10:35 PM
  #37
OrbitalChris's Avatar
crane gold S/A stock studs
Old Jul 3, 2006 | 01:46 AM
  #38
LT1Mike's Avatar
i think imma go for the install and see how they do.. im sure i got all parts...
Old Jul 3, 2006 | 08:46 AM
  #39
Kevin Blown 95 TA's Avatar
Originally Posted by Joe B
Nothing shoud EVER be allowed to rub in that area of a valvetrain(major problem waiting to happen with all the additional harmonics and stress it could cause on parts)........And In my opinion , even for your described useage, I would return what you got for the 7/16 size comp promags(They're a much stronger and better designed rocker) I would also spend the 25 bucks and pick up the larger ARP 7/16 studs to go with them....small price to pay for a ton more strength, but thats just me......good luck with it......
There's good advice here for anyone that wants to take it.
Old Jul 3, 2006 | 08:51 AM
  #40
CANTONRACER's Avatar
Harland Sharp 1.5 rr's here...can't beat them for the money and when you run into big springs. My Crane Gold rr's and my Pro-mags did not work.
Old Jul 3, 2006 | 02:58 PM
  #41
LT1Mike's Avatar
Whats your part list look like for the promags? like springs, retainers, etc etc that way i get a good idea of what i need.
Old Jul 4, 2006 | 10:33 AM
  #42
LT1Mike's Avatar
Comp non self-aligning Pro Magnum 1.6's with ARP 7/16" studs, and GMPP guide plates, hardened pushrods, LT4 Springs... and retainers... hows that sound....?????
Old Jul 4, 2006 | 10:39 AM
  #43
user 647483's Avatar
Sounds pretty complete to me.
Old Jul 5, 2006 | 11:15 AM
  #44
bt96ss's Avatar
I have the GM 1.6 rollers on the SS. I have the 7/16 NSA Promags on the TA. I have had no problems with either although I think the Promags are quieter. I have used the GM rockers for over 3 years and run both cars pretty hard. Of the two the Promags are my favorite but they cost more and required more parts to install.
Old Jul 5, 2006 | 02:40 PM
  #45
yournamehere's Avatar
Not meaning to hi jack the thread,.....
is the stock ratio 1:50 ?
I'm going to pull the heads on my '96 LT1 after a head gasket
mis adventure and I'm thinking check for flatness, clean up valves,
maybe 1:60 for a little more umph ?
Worth it ?
My Camaro has been sitting for over a year while I recovered from a
motorcycle accident and saved money to work on it. I don't want
to cut corners, just make it safe and fun.
