1 3/4" Shorties
Old Sep 23, 2003 | 05:39 PM
  #16
chasmanz28's Avatar
Originally posted by AxeGrinder30thZ
Does BBK make 1 3/4 shorties? Maybe not. I can't remember. I've got SLP 1 3/4" on mine right now. You'll be happy with them.
where's the cheapest place you can buy the SLP 1 3/4 shorties at?
Old Sep 23, 2003 | 06:08 PM
  #17
NiteRider's Avatar
http://www.neweraperformanceparts.com/
399.99 for 93 SLP single cat headers with y-pipe, if you don't care about the little air pump holes being in the back then go for this.
Old Sep 23, 2003 | 06:14 PM
  #18
scoobysnax83's Avatar
Originally posted by NiteRider
SLP is awesome, you won't be disapointed. Having them stainless steel will also save you money on not having to coat them.
You've got to remember that without that coating it is also allowing a lot more heat into the engine bay which is a MAJOR HP killer. Even if you decide to get the SLPs you should get them coated.
Old Sep 23, 2003 | 06:20 PM
  #19
KYWes's Avatar
What's the word on installing the shorties, worse or better then LT's?
Old Sep 23, 2003 | 06:24 PM
  #20
NiteRider's Avatar
Correction... stainless steel is actually a great material for heat distribution.
Old Sep 23, 2003 | 06:31 PM
  #21
It is great for distribution but without a coating much much more of that heat will remain in the engine bay. How can you argue that? Distribution was not the issue.
Old Sep 23, 2003 | 06:35 PM
  #22
NiteRider's Avatar
Distribution out of the engine bay... They will leave less heat in the engine bay then any other uncoated header.
Old Sep 23, 2003 | 06:41 PM
  #23
Point duly and repeatedly noted...
That was the original statement. It simply states that the coating will significantly reduce the bay temps. Nothing more and nothing less. I do not argue weither or not they are the best uncoated heat dispersing headers.
Old Sep 23, 2003 | 06:50 PM
  #24
94formulabz's Avatar
Coating is nice, but in terms of bang for the buck jet hot coating is not the best place to spend your money. Even jet-hot says something only 1-3% gains(someone correct me if i'm wrong but thats what i remember from their great video). We know they are biased towards their product so 300 hp * 1%; 3 hp, BEST case 9 claimed hp. Every lil bit counts, but you could spend that money more effectively somewhere else. I agree with doing it right the first time, but your not cutting off your feet if you don't get them coated.
Now if your headers aren't SS then it's a much better deal if you need corrosion protection too.
I personally opted for a local shops coating on just the headers and not the ypipe for less than half the price of jet-hot. Even if jethot is slightly better i'm sure it's not 2x as insulating justifying the cost.
I'm not knocking jethot either, JMHO and a friendly reminder that they aren't the only option for coating.
-brent
Old Sep 23, 2003 | 06:54 PM
  #25
magius231's Avatar
I bought uncoated SLP's for $250 on this board. If you want a bit more looks/protection, buy them used then have them coated (lots of people lately seem to be having problems with Jet-Hot though, might wanna look at some other places). You could probably come out around $400 for the set instead of like $700 for the coated ones new.
Old Sep 23, 2003 | 06:59 PM
  #26
Could you explain that a little more? It would seem to me that the thermal conductivity and emissivity of low allow stainless is not a whole lot different than mild steel..... hence, the heat loss from either, into the engine compartment would be similar. Coatings reduce heat loss to the engine compartment by reflecting the heat back into the exhaust gas. That reduces heat transfer out of the primaries into the engine compartment, and helps keep the velocity of the exhaust higher, increasing scavenging.
The coating also reduces the tube metal temperature, which reduces corrsosion (obviously this is the one place where stainless all shows some advantage) and reduces stress cracking through heat cycling. Other than the "appearance" factor, and a slightly better corrosion resistance, stainless offers little advantage. Coating both mild and stainless headers makes a lot of sense, IMHO.
Old Sep 23, 2003 | 07:00 PM
  #27
chasmanz28's Avatar
another question guys, if a buy the SLP shorties, i know i dont have to move the cats or y pipe which will pass a visual test, but lets say if a want a new SLP y pipe and high flowing cats will i still pass the visual if i install all these new parts
Old Sep 23, 2003 | 07:08 PM
  #28
Thank you
I thought it was just me
Old Sep 23, 2003 | 09:40 PM
  #29
i387's Avatar
According to the SLP website, the shorty headers and Y-pipe come together as part #30017C. The package DOES have a CARB EO number, so yes. It will pass a visual.
As far as I know, SLP does not make cats. If you're in California, just make sure that the new cats have a CARB EO #.
My wife walked into a conversation and heard "gutted cats". I had the hardest time convincing her that I'm not sacrificing animals...
Old Sep 23, 2003 | 09:47 PM
  #30
Hilarious....
