**UPDATE**Possible bad Fuel Pump
Old Mar 28, 2004 | 06:16 PM
Fast96WS6's Avatar
Exclamation **UPDATE**Possible bad Fuel Pump
I posted about my fuel pump possibly going bad
http://web.camaross.com/forums/showt...hreadid=241972
here are the Fuel Pressure results...
in the "On" position, the car pressurizes @ a whopping 22 psi and barely holds
At idle the car barely reaches 33 psi.
So it looks like the Racetronix kit thats coming in this week will do the job.
Old Mar 28, 2004 | 06:59 PM
Racetronix's Avatar
Make sure you clean your tank out before you put in the new pump.
We have had a higher than normal failure rate on pumps for F-LT1 cars due to their age and rust contamination.
Old Mar 28, 2004 | 07:33 PM
Fast96WS6's Avatar
Thanks for the tip. Good to see vendors interacting with customers on here
Do you have any tips on cleaning the fuel tank? I'll be installing this pump from the "Trap Door" method a lot of people use rather than dropping the rear and exhuast.
Old Mar 28, 2004 | 08:58 PM
Fast96WS6's Avatar
ttt
Old Mar 28, 2004 | 11:28 PM
Racetronix's Avatar
You can not clean the tank using the trap door method.
The tank must be flushed a few times and dried out to be done properly.
Old Mar 29, 2004 | 08:34 AM
Fast96WS6's Avatar
ok, thanks for the info
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
