***Ai 383R long block with TFS 215 heads goes 9.6@139.9mph NA ***
Old Sep 30, 2008 | 02:00 PM
  #16
marshall93z's Avatar
DAMN, that's a lotta MPH for only a 9.6 on an NA car!
Old Sep 30, 2008 | 09:31 PM
  #17
SS RRR's Avatar
Originally Posted by RedLT4Mike
Yeah, it is called for. And same to you too buddy.
So where's the remark that required you to lose your mind and start name calling?
I was merely pointing out that there was an inaccuracy in the compression # and
all of a sudden static compression doesn't matter anymore.
Ah so that's the reason for you to lose your mind and start in on the name calling?
If a static CR matters that much to you then 11.7:1 is still a very street friendly CR on pump gas. There, is that better?
You guys make AI look bad with your constant trolling for an interweb fight.
Geezus... NO ONE was trying to pick a fight. It was YOU who started in on the name calling. It has been posted time and time again how static CR is not important.
I guess I should say I appreciate you being on your toes pointing out that typo and making absolutely sure to say, "It was 11.7:1 which is much closer to 12:1..."
I really don't understand what point you were trying to make, but more power to you.
P.S. I have never bought an AI product, but can appreciate what they offer.
Old Sep 30, 2008 | 10:33 PM
  #18
whyrun's Avatar
I'm not trying to get in on this but hows is static compression not relavant just looking into compression shouldn't a higher static = a higher dynamic???
Old Sep 30, 2008 | 11:34 PM
  #19
tireburnin's Avatar
It depends on a lot of factors including the cam. This current crate engine is designed to run safely and very well on pump fuel. At a 11.7:1 it isn't on the ragged edge. All of this compression discussion is a tangent to the results and car at hand.
I mentioned the compression because it is WAY lower than many compareably fast cars. Most mid 9 second cars run above 14:1. Most mid 9 second cars are extremely light. And every mid 9 second LT1 perviously run is based on a custom one off setup (from intakes to .
Ai could build you this exact motor. Other Ai customers are likely running the same cam (as it was originally designed for fast street/strip cars). Dozens of customers are running the same heads.
Anyone with the money and the desire to set a car on the bumper could purchase this exact setup. I don't think any other LT1 company or machine shop has ever offered such an option.
Old Oct 1, 2008 | 12:18 AM
  #20
SS RRR's Avatar
So if this car shows up to the LTx shootout, like Tiger Woods we'll all be fighting for 2nd place and beyond.
Old Oct 1, 2008 | 06:00 AM
  #21
tomcowle's Avatar
No, there are other fast ones out there that don't post or pay attention to the internet.
Old Oct 1, 2008 | 06:53 AM
  #22
SS RRR's Avatar
Running deep into the 9's N/A?
Old Oct 1, 2008 | 07:56 AM
  #23
T/A lt1's Avatar
Super stock LT1 cars run low 10's on stock heads, compression, stock duration cam, intake etc... so it's not all in the heads/cam like everybody makes it out to be.
Old Oct 1, 2008 | 08:09 AM
  #24
whyrun's Avatar
what would be considered to high a compression ratio for pump gas 93 octane in a LT-1 I know there's alot of variables I would think its around 13.0:1 possibly..
That car is a really setup I admire him for the time and effort put into it.. I would like to think I could do the same but my check book won't allow it. LOL
Old Oct 1, 2008 | 08:24 AM
  #25
bombebomb's Avatar
I believe iv heard of people running 13:1 on 93 in the lt1. Im running 11.9:1 or so.
Old Oct 1, 2008 | 08:34 AM
  #26
tomcowle's Avatar
Yes, running deep into the 9's AND running lt1 specific heads, not conversions. There are 2 guys locally to me, 1 is an sb2.2 based 396" lt1 running 9.30's and the other is 383" trickflow headed lt1 running in the 9.40's. Both cars are really nice and they don't run training wheels.
Stock eliminator lt1's have run in the low 10's with non ported factory heads, stock lift cams, stock intake and etc.
Old Oct 1, 2008 | 09:50 AM
  #27
SS MPSTR's Avatar
True, and they run on the threshold of the letter of the rule too, with other 'tricks' that comply. I have two friends that run this class, and their cars are not cheap, put together with painstaking attention to detail, with countless hours in suspension tweaking. You find that 'stock' is a relative term.
Old Oct 1, 2008 | 10:03 AM
  #28
ulakovic22's Avatar
Great setup, congrats!
Only small issue I have is saying someone can go to AI and get this exact same setup. While it's true, you can get the same H/C motor built, I seriously doubt you will get the same results as Rick. Not taking anything away from AI, but at the same time don't take anything away from Rick and his crew who I'm sure spent an enormous amount of time tweaking the whole car.
While "stock" is a relative term you can't argue with stock untouched heads/intake and stock "like" lift/duration cams running low 10's.
Old Oct 1, 2008 | 10:29 AM
  #29
SS MPSTR's Avatar
I agree, and no doubt. But I take some exception with "untouched" heads. They're not $3k+ per set because they've never been touched.
Old Oct 1, 2008 | 10:54 AM
  #30
Z97LT1's Avatar
Very nice. These guys sure aern't sitting still and waiting for everyone else to catch up. Who ever really thought we'd see streetable NA LT1s over 500rwhp?
