when using band clamps for y pipe/header install should i use alum. foil?
Old Sep 24, 2004 | 02:02 PM
bluecmaro96's Avatar
i read somewhere to wrap the connections with aluminum sheeting or something, should i use aluminum foil underneath my band clamps? what is the aluminum stuff called i can buy at lowes that will work for this so i get a good seal?
Old Sep 24, 2004 | 02:50 PM
teke184's Avatar
Re: when using band clamps for y pipe/header install should i use alum. foil?
i've never heard of this...
but from a chemical standpoint, the worst thing you can do is put aluminum against steel. it causes a chemical oxidation and is VERY quick and destructive.
the bands should seal well enough for your purposes. mine seem to.
Old Sep 25, 2004 | 08:21 AM
If you’re using clamps and are still having exhaust leaks try buying some aluminum tape that can be found at Lowes or home depot. Wrap the tape around the collector; whether header or Y pipe, for thicker area for the clamp to seal up too
I READ THIS ON LS1 TECH. someone also said that band clamps arent great to use because on slip fit connections they tend to leak, should i go to lowes and buy aluminum tape? should i also just go ahead and make 2 block off plates for the a.i.r.? so i dont have my check valves making noises? i read that most header installs have this problem and if i wanna keep my air i need to make block off plates, should i do this? can i also use hi temp silicone on the longtubes where they attach to the heads?
Old Sep 27, 2004 | 02:23 AM
AL SS590 M6's Avatar
Moderator
Why? Use stock multilayer steel gaskets, clean and dry. They work great.
Old Sep 29, 2004 | 12:18 AM
SS1LE02's Avatar
I agree. I've taken off my headers 3 times and reused the same stock gaskets that came on the stock manifolds. No leaks at all. Those multilayer gaskets work GREAT. Now the band clamps are a different story though.
Old Sep 30, 2004 | 01:22 AM
uh oh... ok, lets hear your band clamp horror story and how you fixed the problem please dont say weld it
Nov 18, 2023 07:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Rich_z28
Aug 27, 2002 12:20 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
