When is it nessacary to?
Old Apr 17, 2007 | 03:25 PM
mook99TA's Avatar
Change to a different length pushrod? Or is the stock 7.4" ok with most applications. I want to run a 232/232 cam with right around .600 lift will the stock lenght pushrods be okay to run with that?
Old Apr 17, 2007 | 06:32 PM
CustomSSI's Avatar
You should be fine.. Best thing to do as we always recomend it get comp cams pushrod length checker...
http://customssi.com/cart/index.php?...roducts_id=243
Use that make sure 7.4 is what you need (where your heads milled at all or anything?) then order your pushrods...
Old Apr 17, 2007 | 08:15 PM
mook99TA's Avatar
no still the stock heads just looking at a new cam.
Old Apr 18, 2007 | 07:32 AM
AL SS590 M6's Avatar
Moderator
The only time that you need to worry about pushrod length is if you change base circle diameter on the cam or do head work that changes the length/height of the valvestems.
Old Apr 18, 2007 | 08:48 AM
SSpdDmon's Avatar
Most aftermarket cams with higher lift like that have a smaller-than-stock base circle. I believe you can calculate it off of the cam card. Yes you should always measure with a PR length checker. But, most likely a 7.425 pushrod is what you will need if the only change is the cam.
Old Apr 20, 2007 | 07:16 PM
IrocSS85's Avatar
exactly
93camaroLT1
Nov 28, 2004 03:50 PM
Brent95formula
Aug 24, 2004 01:39 PM
whitemusclez28
Jul 20, 2004 09:59 PM
Toker420
Jul 20, 2004 06:12 AM
TrouserSnake
Feb 5, 2004 03:06 PM
