Wash the LS1 motor?
Old Aug 10, 2003 | 03:39 PM
  #16
DS01Z28's Avatar
Hey KevinSS,
What does the foam carpet cleaner do?
Daryl
Old Aug 12, 2003 | 11:55 PM
  #17
JeffHooke's Avatar
Why does the engine have to be on when you are hosing it off? And is this just the engine or the entire engine bay that we are talking about?
Old Aug 13, 2003 | 01:13 PM
  #18
chevyzman1998's Avatar
its just a habit i have to leave the engine running.
Old Aug 14, 2003 | 12:48 AM
  #19
AL SS590 M6's Avatar
Moderator
Originally posted by robvas
Go to autozone and buy a can or two of GUNK FOAMING degreaser.
Drive to car wash.
Pop the hood.
Coat your entire engine. Everywhere.
Put in quarters.
Spray the snot out of it.
Enjoy your clean engine.
Don't get inside your alternator or spray the electronics directly and you'll be okay.
And then again I washed mine off carefully with a water hose and it missed for a week
Old Aug 14, 2003 | 07:33 AM
  #20
350 HRSS's Avatar
See, that is the crap I am worried about right there!
Old Aug 14, 2003 | 08:00 AM
  #21
98BlueWS6's Avatar
I sprayed mine off a couple months ago. It ran fine afterards but the belt still squeeks
Old Aug 14, 2003 | 09:21 PM
  #22
BadAndy743's Avatar
Make sure you don't use "Engine Brite" cleaner. It is also made by Gunk. It cleaned most everything pretty well, and put a little shine back in the block too. But it FRIGGING ATE MY AIR LID!!!! The stuff must have something like acetone in it or something. All the composite or relly heat resistnat plastics were ok, but the lid started discoloring as plastics do when they start to dissolve. Don't use it. Use simple green.
Old Aug 14, 2003 | 10:48 PM
  #23
mirroredfire2's Avatar
I believe you leave the engine running so you don't crack the block.. I don't wash inside my engine.. but if the engine goes from hot to very cold it will go bye bye
Old Aug 14, 2003 | 10:53 PM
  #24
FastrDamnit!'s Avatar
Lightbulb
I haven't cleaned my LS1 yet but when I did on my old LT1 I used Simple Green and used a full gallon to swish water onto certain areas (vs. a running hose which will splash everywhere). Worked great
DirtyDaveW
Mar 15, 2015 07:01 PM
Jazsun
Dec 29, 2014 12:14 PM
ChrisFrez
Nov 23, 2014 10:33 AM
LT1runner
Aug 3, 2002 05:44 PM
