Problems with short stick shifters
Old Aug 7, 2003 | 04:21 PM
quick's Avatar
Do any of you who use Lou's short stick with the stock shifter or other shifter, or use any other kind of shortened shifter, does/has this caused any unusual wear or damage to the M6 transmission? If so, what kind of problems developed?
Old Aug 7, 2003 | 04:41 PM
blacknight's Avatar
I'm using a Lou's and love it. I would however like to have a Pro 5.0 for the sake of having shifter stops that way I could shift much harder and not worry about over travel and damaging shifter forks. The only negatives about shorter handles or shifters is you have more noise since theres no rubber between the handle and shifter and also you loose leverage so for some they can't shift as fast because of this. The only way a short shifter could cause problems and damage is if the shifter stops aren't properly adjusted. Adjusting them is very easy.
Old Aug 8, 2003 | 08:25 AM
teke184's Avatar
i've had a lou's stick on both my camaros (96 and my new 99) and have had no problems with them. i installed a short thow shifter from an SS (slp option) and the lou's and it makes a fantastic shifter for a good price...
Old Aug 8, 2003 | 10:24 AM
camaro322hp's Avatar
i love my lou's. haven't had any problems. stock shifter. also, i like the noise it makes, like a clicking beteween gears. sounds nice.
Old Aug 8, 2003 | 09:13 PM
kinyu's Avatar
I have lou's with a 5.0 ... everything is kosher.
Old Aug 8, 2003 | 10:22 PM
ratio411's Avatar
Modded my stock unit.
Love it.
It is noisy as posted before.
The post about shift stops is questionable. The T56 is not supposed to need external shift stops. To my knowledge, aftermarket shifter instructions say to remove stops when installing on a T56.
Correct if I am wrong on this.
Dave
Old Aug 8, 2003 | 10:23 PM
02CamaroZ28's Avatar
lou's+stock hurst=
Clicks to let you know you're in gear, short throws...I slam gears constantly with it still in great condt.
Mark
Old Aug 9, 2003 | 01:44 AM
AL SS590 M6's Avatar
Moderator
Love it.
Dave
OK. My Pro 5.0 had instructions for adjusting the stops on a T56 app. But I will admit that I have an early one. It's 5 years old now.
I believe in the stops because it protects the weak asp aluminum 3-4 shift fork.
Old Aug 9, 2003 | 01:56 AM
SS1LE02's Avatar
With my Qwik Stick I've had no problem in over two years on either my 99SS or my 02SS.
Old Aug 9, 2003 | 03:27 PM
Flat_Tire_'s Avatar
I've got the Pro 5.0 right now with the Pro 5.0 stick ... I had it with a short stick but the short stick didn't angle to the left at the base of the stick the like the Pro 5.0's, making it difficult for me to get it in 6th and reverse ... or i may just be a weeny. if ya end up with the pro 5.0 and think the stick is too tall .. go get 1/2" to 3/4" cut off the top .. and then go get the lou's short stick if you're still not satisfied.
Old Aug 11, 2003 | 05:48 PM
Jake77444's Avatar
This is what im getting
http://store.yahoo.com/afterthoughts...50towshif.html
Old Aug 11, 2003 | 06:16 PM
Ken S's Avatar
Had the Pro 5.0 for 3 years now, only problem I had was the stick coming lose from the base, which I fixed with some locktight, never had a problem with it again.
Yes, you can cut quite a bit off the stock of the Pro 5.0
I too adjusted the stops in my shifter.. Doesn't hurt to have double protection.
Old Aug 11, 2003 | 06:43 PM
chuck's Avatar
I am very happy with my Lou's short stick. Despite serious hard use, the only thing that has broke on the car since new was the spring popped off the clutch pedal.
At one time I had a Ripper in my old '98 Z29 and the "factory" Hurst with the LSS in the T/A. I pulled the Ripper to be legal for a class I was racing in, and opted to sell the Ripper (I would have put it in the T/A if I preferred it). Just this weekend a friend that was driving my car asked what shifter it was, and is going to order a LSS for his T/A.
slocody
Feb 10, 2003 01:04 PM
GRN96WS6
Sep 8, 2002 10:45 PM
slothgrant
Aug 22, 2002 03:01 PM
jim88iroc305
Aug 13, 2002 09:24 PM
kurob25
Aug 5, 2002 08:03 PM
