Repairing a cracked oil pan
Old Aug 10, 2003 | 11:07 PM
jd13's Avatar
Somehow my oil pan cracked. I have no idea how, but I noticed it while swapping my springs yesterday. It's a little less than a 2 inch long crack in the middle towards the rear of the pan. It leaks about 1 drop a minute.
I tried to seal it up with some instant steel stuff. It worked for a little, but by the end of the night it was leaking again. I searched and didn't find anything about this.
What is involved on dropping the oil pan on an LS1? These are my options, in order right now of how I plan to do this. Please tell me a better way or point out a site with directions. Please!
1. Take it to a local shop and have them weld it.
2. Drop it myself and try some JB weld.
3. New oil pan.
Old Aug 11, 2003 | 12:21 AM
Chris B's Avatar
I would probably get a new pan, or at a minimum have it welded properly. I *believe* the oil pan on the LS1 is actually a stressed member, so I would want to make sure it has as much integrity as possible.
Old Aug 11, 2003 | 05:48 AM
This should be posted on LS1 Tech..... moving it there.
Fred
Moderator
Old Aug 11, 2003 | 10:45 AM
Constrictor98TA's Avatar
Do NOT repair your pan for any other reason than to limp it home or to a dealer to get replaced.
Unlike any other Chevy SB engine, the LS1 oil pan is a structural part of the engine block. Its job is not only to hold oil, but it is the bottom part of the block, and as Chris B said, it must endure quite a bit of stress. I know it sucks, but you will need to replace it if you care about your car or its engine.
Old Aug 11, 2003 | 07:34 PM
2002Z28SSConv's Avatar
My plan of attack was to support the engine with my STB and drop the K member. But I was able to get JB Weld to seal up the damaged spot. It was only a nick on a corner so structural integrity wasn't a problem. No Leaks though.
http://2002.cz28.com/OilPanLeak.jpg
jer4251
Sep 21, 2020 09:42 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
siguy
Nov 27, 2014 10:07 AM
Elcojoe
Nov 17, 2014 10:27 PM
