O2 sensor question
Old Dec 10, 2005 | 12:04 AM
T56LS102's Avatar
O2 sensor question
I just got a 02 Z28 6 speed and 2 days after my check engine light came on i checked it out and on the OBD2 scaner came up with catalest below thershhold bank 1 what do you guys think??? is it the O2 sensor?
Old Dec 10, 2005 | 07:20 AM
Z28_95RIDE's Avatar
Re: O2 sensor question
If you know the code (ie P0422) then you can do a google search.
It sounds like the O2 sensor after the catalyst (or lack thereof). Check connections first. It could actually be the converter itself but less likely.
Regards
Old Dec 10, 2005 | 01:14 PM
2001NBMZ28's Avatar
Code P0420? Lot's of info on this - click search button in this forum and type in the code. My money is on a bad cat if you're stock. Welcome to the board.
Old Dec 12, 2005 | 09:13 PM
SSpdDmon's Avatar
Before calling it a bad cat, I'd check the sensor. Switch the sensors behind the cats. If the problem stays on the same side, it's most likely the cat (but could be the connection). If the problem follows the sensor over to the other side, then it's most likely the sensor.
Old Dec 12, 2005 | 10:11 PM
T56LS102's Avatar
Well like an idiot i reset the code so its not there any more but i guess if its bad it will come up agean
Old Dec 14, 2005 | 08:32 AM
AL SS590 M6's Avatar
Moderator
Above is a proven and the best/cheapest way to determine what's really wrong.
Old Dec 17, 2005 | 04:38 PM
slayer6x6's Avatar
I dont mean to hijack the thread, but is bank one the driver side?
Old Dec 18, 2005 | 09:42 AM
2001NBMZ28's Avatar
Yes bank 1 is driver side, bank 2 is passenger.
Old Dec 18, 2005 | 09:53 AM
Kataklysm's Avatar
try hitting the cat you think is bad with a rubber mallet, if it rattles it's junk if not then it's possible it's still good. Now don't think if it doesn't rattle that it's not bad either, and don't smash it, just hit it kinda lightly.
mikey4play
Mar 15, 2015 11:45 AM
Queens94z28
Dec 20, 2014 09:11 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
