ls1 or lti???
Old Nov 19, 2004 | 02:38 PM
  #16
anasazi's Avatar
Re: ls1 or lti???
an LT1 caused world war 2
Old Nov 19, 2004 | 02:41 PM
  #17
anasazi's Avatar
Re: ls1 or lti???
oh yea, and who can forget the fact that hitler didn't die due to a bullet, he got hit by an LS1 powered vehicle, thus an LS1 ended World War 2, a war started by an LT1.
Old Nov 19, 2004 | 03:03 PM
  #18
FLeXNuTZ's Avatar
Re: ls1 or lti???
The LT1 will start WW3 against the LS1 and emerge victorious because iron is better than aluminum Also, LT1s will be better at defending our country against terror attacks because of the power of "iron"
Old Nov 19, 2004 | 03:12 PM
  #19
falchulk's Avatar
Re: ls1 or lti???
Originally Posted by Shackleford
Don't forget the LT4. Upgraded version of the LT1. LS1s don't stand a chance against an LT4. OH YEAH!
I always thought that the lt4 barely equaled the LS1
Old Nov 19, 2004 | 03:32 PM
  #20
BirchMan98z's Avatar
Re: ls1 or lti???
Originally Posted by FLeXNuTZ
All I'll say is,"Watch out LS1 guys, watch out..."
we're real scared.
Old Nov 19, 2004 | 03:42 PM
  #21
Re: ls1 or lti???
The LT-4 is 330 hp and is somewhat comparable to an LS-1, but does NOT have more hp and torque. It has a higher compression ratio, slightly better heads, and a 6300redline. the lt-4 equipped 'vettes were good for low low 13's, sometimes into the 12's. Most people manage about a 13.7x with an lt-4 fbody. As far as LS-1's not standing a chance? Wake up buddy. Are you sure you weren't thinking about the LT5 zr-1 engine?
Old Nov 19, 2004 | 04:58 PM
  #22
Capn Pete's Avatar
Re: ls1 or lti???
Screw you all....................an IRON block, 6.0L LS2 will kill everything, bar none!
Although, the 7.0L LS7 should be a handful.................maybe not indestructable, but you'd have to catch it first!!
Old Nov 19, 2004 | 06:14 PM
  #23
FLeXNuTZ's Avatar
Re: ls1 or lti???
Originally Posted by BirchMan98z
we're real scared.
Oh you will be. I will go BirchMan98z hunting in the near future
Old Nov 19, 2004 | 06:18 PM
  #24
FLeXNuTZ's Avatar
Re: ls1 or lti???
Whoa, wait a minute here. The LSx head is far superior to the LTx head no matter what. Period. Just check this thread for proof
http://web.camaross.com/forums/showthread.php?t=318997
Old Nov 19, 2004 | 09:02 PM
  #25
Antz97ZNJ's Avatar
Re: ls1 or lti???
The LT4 has more horsepower and torque. Both have their pros and cons, but I'd generally assume the LT4 was an overall better performance engine. Higher potential, I guess.
Actually thats a false statement....LS1's generally dyno higher then LT4's
Old Nov 19, 2004 | 09:26 PM
  #26
FLeXNuTZ's Avatar
Re: ls1 or lti???
So in all honesty LT4 AFR heads that are worked to the max (from AI for example) should easily out perform the LS1 heads, right?
Old Nov 19, 2004 | 09:46 PM
  #27
twozs's Avatar
Re: ls1 or lti???
get a room, for christsake! more money = more power!
Old Nov 19, 2004 | 10:57 PM
  #28
meengreen 94z's Avatar
Re: ls1 or lti???
No the most Ive heard out of any AFR LT4 227cc's or 215rr's is in the 330-340cfm intake range(although more is probably possible). Ive seen a few sets of LS6 heads in the 350-360cfm range, and Ive heard of someone getting near 370cfm, but I doubt it had decent port velocity. But theres other alternatives, you can convert SBC to reverse flow cooling and put them on an LT1(which you cant on an LS1). And if anyone ever gets a set of LT1 ARAO 32 valve heads to work(Bobby Simpson"The Big Show" is close), I dont see LSX castings being able to match their flow capability's(around 400cfm).
Really its more about the overall setup than just the heads. Joe Overton has AFR 227cc's on his LT1 and up until recently outran all NA LS1's using far less cubes than they were(his best is a 9.36 using 388ci)
Old Nov 20, 2004 | 01:48 AM
  #29
Re: ls1 or lti???
Hm. think I got misunderstood. I meant LT-4 heads were better than lt-1 heads, not LS-1 heads. LOL And what does that link have to do with heads anyway? C5R heads flow well over 400cfm, and the new c6 z06 heads are supposed to flow near 370 stock. LS-1/6 heads flow great from the factory, and are able to flow some awesome numbers when ported to the max.
Old Nov 20, 2004 | 02:16 AM
  #30
FLeXNuTZ's Avatar
Re: ls1 or lti???
I stand corrected.
