LS1 Blocks
Old Feb 28, 2006 | 10:33 PM
pitbull14218's Avatar
LS1 Blocks
How durable are they? They are 2 bolt mains? What can they handle up to how much hp? thanks
Old Feb 28, 2006 | 10:35 PM
SStrokerAce's Avatar
Re: LS1 Blocks
LT1 blocks?
Old Feb 28, 2006 | 10:36 PM
chevelles101's Avatar
Re: LS1 Blocks
Wrong section if you are really asking about the LS1 or are you mistakedly refering to LT1?
Old Feb 28, 2006 | 11:41 PM
Re: LS1 Blocks
Last I checked, LS1 blocks are 6-bolt mains.
Not sure why this was posted on "LT1/LT4 Engine Tech".... moving......
Old Mar 1, 2006 | 12:06 AM
Z28LT1_Just_Nasty's Avatar
Re: LS1 Blocks
They are also 6 bolt mains because it's an aluminum block. Everything pretty much evens out.
Old Mar 1, 2006 | 09:15 AM
AL SS590 M6's Avatar
Moderator
Re: LS1 Blocks
A local ran his stock block, stock crank LS1 to well over 1000hp without breaking either part.
Old Mar 2, 2006 | 09:04 AM
Bayer-Z28's Avatar
Re: LS1 Blocks
There was a NICE black SS in one of the latest issues of GMHTP, running 1000 hp w/ a blower. For an FI motor, the breaking point is 'typically'....I use this term loosely... 600-800hp Blown, 8 lbs of boost w/ a mild cam and heads. Usually, heads aded to a cam and blower motor will throw #7 out.
And yes, 6 bolt main. They're worth rebuilding w/ forged internals, if that's what you're getting at. Just can't punch it out. Have to get a re-sleeved block, or a C5R block.
Old Mar 2, 2006 | 09:59 AM
Greed4Speed's Avatar
Re: LS1 Blocks
There are plenty of cars running 11's and 10's w/the stock rotating assembly in the stock block. Thats durable enough for me.
Old Mar 3, 2006 | 04:26 AM
MonkeyBoneSS's Avatar
Re: LS1 Blocks
I have seen a few Camaros run high 10's with just a CAM on a stock block, stock heads, and stock internals! That is pretty good in my books.
Old Mar 3, 2006 | 11:33 AM
RussStang's Avatar
Re: LS1 Blocks
I don't know if I agree with this.
Old Mar 3, 2006 | 07:05 PM
wdtiger's Avatar
Re: LS1 Blocks
Care to expand on this?
Old Mar 3, 2006 | 08:16 PM
Re: LS1 Blocks
The LS1 main caps are powdered metal and significantly stronger than the LT1’s cast caps. A total of six bolts retain each main cap to the block, including the two cross-bolted fasteners.
So a beefier main cap and 4 more bolts than an LT1, 2 of which are perpidicular to the others and go through the engine skirt.
Just because it is steel, does not mean it is automatically stronger than Al. There is more to mettallurgy than that.
The LT1 has nothing on the LS1 when it comes to the bottom end.
Sergio
Jan 27, 2016 04:27 PM
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
