11.2-1 OK with 93 pump gas? P/V clear?
Dart 205's on the way . I am looking to mill them .020, use GM MLS gaskets and install the F14. I have been told that the compression ratio will be close to 11.2-1. Will 93 octane pump gas be OK with this set-up?
One more question, will piston to valve clearence be an issue? Thanks
Re: 11.2-1 OK with 93 pump gas? P/V clear?
Would love to know the numbers once you get the set up complete, please post the results. I am thinking about the Darts not sure just yet. Hopefully your numbers will persuade me to buy them!
It's going to depend on the tuning ... my set up is 10.9 to 1 with a moderate cam ... the difference between a tune on 91 - that's all we get here in CA - or 100 racing gas is about 15 rhwp.
If I run the 100 octane tune on 91, it sounds like someone dropping a bag of marbles on hood.
If you're serious about getting the maximum power for the track; either get LS1 Edit so you can down load your 100 octane tune for the track or get a second PCM with your race tune and swap them out for the track.
Magenta_Hearts
03-22-2015 03:36 PM
Magenta_Hearts
03-05-2015 07:01 AM
dmaastr
9
07-01-2002 02:22 PM
