LS1 to 500hp, what is the best route?
Budget heads, Futral fm13, 90/90 intake and longtubes 435/400
Had to upgrade the stock fuel system about 2 months after the install.
The only reason that I went with the 90/90 intake and tb was that I was going to do a 402 at a latter date.
Well I just spent the last ten minutes trying to find my flow sheet. No luck. The heads are Absolute Speed Stg. 2 5.3's. I was lucky, one of the last to get the combination before he went out of business.
Got them right from TEA. I have a lot of things that would bring the power up. Most guys over 480 are running true duals, mine is through a cat back. I would be over 480 just with that change. I also don't have them milled to 58-59 like most, I am at 61-62cc, I have a bad port job on my lower FAST manifold, and I could go bigger on the cam. Right now I have the stock rear in it and the builders told me the big 500 horse cams would be too large for stock gears.
