LS1 to 500hp, what is the best route?
Old Feb 4, 2007 | 08:16 AM
  #31
YBNORMEL's Avatar
Budget heads, Futral fm13, 90/90 intake and longtubes 435/400
Had to upgrade the stock fuel system about 2 months after the install.
The only reason that I went with the 90/90 intake and tb was that I was going to do a 402 at a latter date.
Old Feb 4, 2007 | 10:20 AM
  #32
teke184's Avatar
not bad considering the budge heads...what was the flow??
some high flowing top shelf heads and you'd be pushing the 450rwhp mark
Old Feb 5, 2007 | 06:41 AM
  #33
YBNORMEL's Avatar
Well I just spent the last ten minutes trying to find my flow sheet. No luck. The heads are Absolute Speed Stg. 2 5.3's. I was lucky, one of the last to get the combination before he went out of business.
Old Feb 7, 2007 | 06:04 PM
  #34
MadKilla's Avatar
I am at 472 RWHP now with TFS 215 heads and a somewhat large cam. With true duals, SD tune and another cam I should hit the 500 mark.
Old Feb 7, 2007 | 06:58 PM
  #35
AL SS590 M6's Avatar
Moderator
Are your TFS heads as cast or ported by TEA?
Old Feb 8, 2007 | 08:34 AM
  #36
Kraest's Avatar
Retired
My guess is cast. They are 215cc 13.5 degree heads and have been making consistently 480-500 rwhp on stock bottom-end 346s.
Old Feb 8, 2007 | 09:10 AM
  #37
MadKilla's Avatar
Got them right from TEA. I have a lot of things that would bring the power up. Most guys over 480 are running true duals, mine is through a cat back. I would be over 480 just with that change. I also don't have them milled to 58-59 like most, I am at 61-62cc, I have a bad port job on my lower FAST manifold, and I could go bigger on the cam. Right now I have the stock rear in it and the builders told me the big 500 horse cams would be too large for stock gears.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
