K&N FIPK or High Flow Lid on an LS1?
Originally posted by blacknight
Your converter, lower gears and shiftkit should be considered POWER mods.
Most high stall converters cause a car to loose MPH. MPH = HP
A shift kit makes absolutely no horsepower at all.
And a change from 3.23s to 3.42 making horsepower? You really don't know much about cars, do you?
These things make a car quicker not faster.
Originally posted by Black01_Z
Thank you. You are running traps of 12.1 @ 111 from a convertor and gears that I dont have. So you just proved your own point worthless since you attributeed the sole cause of your higher mph b/c of the lid. Convertor + gears make car faster, thus higher trap.
Originally posted by AL SS590 M6
Yes and we also noted that you had more mods too
By the way a properly designed and efficient TC will give you more MPH. That's part of Mike's sales pitch for the 9" TCs, such as the ST3500 and now the SS series ... thier efficiency and top end pull - I recently stepped up to TCS 9" 3800 stall and picked up 2 mph at the top ...
my car picked up more sotp power from the free ram-air mod than the lid. imo, the fipk has an advantage over just a lid because it isn't breathing through that thin, little slot beneath the stock airbox's filter. open up the bottom of that box though (free ram-air mod, ftra, slp cai, ssra) and you get most of that back.
what you want is an airbox that doesn't go very negative in pressure at wot. i feel that a good cai/lid will do that as well as the fipk. the benifits of the lid/cai (or real ram-air) combo is that you get real cold air all the time, or so it would seem.
This thread is about a lid vs FIPK not about argueing at one another. If you wanna argue back and forth then send pm's to one another all week long.
Originally posted by jthomas
... the benifits of the lid/cai (or real ram-air) combo is that you get real cold air all the time, or so it would seem.
Besides if you believe in the benifit of the 2 inch by 14 inch opening of the !FRA .. try the 2foot by 14 inch opening of removing the washer reservior and shroud ...
Originally posted by V6toZ28
you make an incorrect assumption that the FIPK is getting something other than ambient air
besides if you believe in the benifit of the 2 inch by 14 inch opening of the !FRA .. try the 2foot by 14 inch opening of removing the washer reservior and shroud ...
Originally posted by chuck
my IAT temps were up. I switched to a lid and have been happy since.
If you are in line waiting for your run, the engine bay will heat up and the FIPK may draw in hotter air. But if you keep the hood up and let the hot air out the problem could be eliminated?
Its just an idea.
Originally posted by lock down
does any 1 have pictures of the ssra+ tsp lid already set up in the car, if so can you pls post?
and if any 1 has the pics of the fipk set up in the car can you also pls post?
THANKS
THANKS
www.austinperformanceinc.com
BTW, all lids look pretty much the same.
CobraEatr
Jul 29, 2002 11:46 AM
dmaastr
9
Jul 1, 2002 02:22 PM
