I've Bypassed VATS, Replaced the Starter and Battery....Still has Starting Problems.
Old Jul 10, 2011 | 11:03 PM
  #16
Slappy3243's Avatar
Re: I've Bypassed VATS, Replaced the Starter and Battery....Still has Starting Proble
Originally Posted by Melee Penguin
[ismg]http://blogs.yorkschool.com/yorkstudents/fmoretzsohn13/files/2010/10/IMG_3062-1024x768.jpg[/img]
Always the first thing I think of when I see VATS. I have even included a similar response to yours when a VATS thread comes up .
As far as the OP goes, what happens when the car is running and you go WOT? Does the car bog or seem to choke at all? This would indicate a fuel pump issue as well.
Old Jul 11, 2011 | 07:04 AM
  #17
94Camaro_Z_28's Avatar
Originally Posted by stars1010
That's an interesting idea, you may be onto something. After the I did everything above I turned my key to on (not start) for a few seconds and let the security light go off then fired it up. That was the shortest/best start time I've had today.
Could by fuel pump be going out or fuel filter be ready to swap out?
So lets clear things up a bit. When you say it takes a up to 2 turns of the key to start, is the motor turning over the whole time and just not catching? From the OP, I thought you meant it wasn't turning over.
If it's the first, I'll say it's the check ball in the fuel pump letting pressure bleed off requiring a longer prime, thus extended cranking. If it's the later, I say ignition switch.
Old Jul 11, 2011 | 11:37 AM
  #18
WhiteHawk's Avatar
I usually go for the headshot.
And get a fuel pressure gauge on that car.
-Geoff
warmeck
Feb 5, 2015 11:04 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
